Go Back   Home > Forums > General Interest > Car Audio
Old 2nd August 2009, 02:35 AM   #1
Default t30001bd schematics
Hi guys, i'm an italian boy, and you are my only hope. I was asked to repair 2 of the amps in subject, they had received several fixes, and many mosfets and transistors replaced I think were badly chosen. So I have 2 amps with all the transistor to be changed, that are, to be more understandable, those screwed on heatsink, starting to the left, and going to the right. The problem is that someone removed them, so I haven't any idea of what I gotta put there, I've known that on the left-front side they are IRFP260, is it correct?But after this, I don't know anything anymore. So can you give me a schematic of this Amp so I can buy the correct components?or, if it is impossible, at least a list of all the transistor from the left-left till the right-right side of the amp (to be clear __ __
on the 4 sides we have transistors fixed with screws, i need them...please, I'm desperate!
I'm expert so... do not persevere with me
Old 2nd August 2009, 02:46 AM   #2
I do not have a schematic, but I do have one of those on my bench. All of the output devices in the one I have are IRF-P3415. Notice the P This amp is in original state. There are 16 total.
If it ain't broke Don't fix it
Old 2nd August 2009, 01:25 PM   #3
Above info is for this amplifier. Make sure this is what you have before ordering any parts.
http://ampguts.realmofexcursion.com/...ower_T30001bd/
Old 2nd August 2009, 09:16 PM   #4
uhm...i've read here Rockford Fosgate - T20001bd
and i noticed that they would be the same of the 20001...is it possible?are you sure about that?However, i would need also the right side of the amp, to be clear the power supply, because even there I have lots of components blowed...In the pictures unfortunately I'm not able to see the code of the components, however perhaps I can get it done.
Old 2nd August 2009, 10:13 PM   #5
The supply of the amp I have is in perfect working order and has never been repaired. I will be happy to get you pictures of the supply parts also.
Old 2nd August 2009, 11:54 PM   #6
nothing, the picture is too small to see the numbers and letters..waiting for you...
Old 2nd August 2009, 11:54 PM   #7
ok, if you can, via email or directly here, were you want...so you're sure that the amp is a 30001 and not 20001...bha..
Old 3rd August 2009, 12:52 AM   #8
Does your amp have 16 output devices? I am sure that mine is a 30001.
Old 3rd August 2009, 03:11 PM   #9
yes, they are 16. But, as I told you, I need also the right-side components. Can you give me some pictures of both side of components so I can replace them?
Old 4th August 2009, 01:52 AM   #10
I will take pictures of the entire amplifier. I know you need power supply pictures too. I was asking about the 16 output devices to reassure YOU that I had the amp that you needed pictures of.
BOSE Schematics DENSO Schematics packer Car Audio 6 25th June 2007 10:55 AM
SAE schematics drfeltbetr Solid State 2 16th March 2004 08:39 AM
Page generated in 0.10154 seconds (74.33% PHP - 25.67% MySQL) with 11 queries
