I just recently replaced the flex cable for the faceplate for the third time.
I've owned the radio since late 2002 and I still love the radio to this day, the newer Kenwoods still don't compare to it IMO. The issue I'm having is with the faceplate. Its just stuck in one spot. I didn't take the radio apart past the point of replacing the flex cable. Everything was working fine before the cable messed up. I OHM checked everything and all of the connections are good. I unplugged the faceplate motor from the board and ran five volts to it and it works fine. I even hooked my meter up to see if power was going to the faceplate motor when it turned on and there was nothing at all. Besides the faceplate not moving the radio is working fine, I just can't change the cd's and the faceplate doesn't hide when I turn the key off. Thanks. |
#2 |
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Email sent.
#4 |
Well, I tried the faceplate/flex cable on a known working radio and I still got nothing.
I also tried the other radios faceplate and motor and got nothing. So it has to be the flex cable.. Everything has a good connection and isn't shorting out.. I'm at a loss... I really don't want to pay $30 at the local repair shop to have the people tell me its the flex cable.. Even though I just bought it last week... I really would rather not spend another $20 for a new flex cable, the store I got it from on ebay is refusing to send me a new one. |
#5 |
You can remove the worm gear off of the motor, and open and close the face manually. I have had people that were tired of having to replace the ribbon cables. If you remove the gear and unsolder the motor from it's cable to prevent it from trying to close when you turn the deck off. Not flipping it over everytime you turn the car off will extend the life of the cable.
If it ain't broke Don't fix it |
| NAD 3020 Faceplate | reddish75 | Solid State | 0 | 13th February 2009 03:05 PM |
| meter on the DIY amplifier faceplate? | gychang | Parts | 17 | 1st November 2007 03:37 AM |
| Vifa Xt25 Faceplate | bowdown | Multi-Way | 19 | 3rd November 2005 01:37 AM |
| bosoz faceplate pics! | cowanrg | Pass Labs | 14 | 29th May 2005 08:38 PM |
| Aluminum Faceplate Stock | erix | Swap Meet | 1 | 12th May 2004 04:39 AM |
| Page generated in 0.08268 seconds (73.30% PHP - 26.70% MySQL) with 10 queries |
