I recently acquired a JVC KD-S31 CD receiver. It will load and eject CDs, but will not play them or let me do anything else. It's like it's not turning on fully. I tested it out on a computer power supply. I connected the ACC wire, the power wire, and the remote-turn-on wire to the positive of the supply. The ground is connected to the ground. Am I missing something? Thanks.
#2 |
Some head units will do this if the ignition wire has no voltage. If there are no blown fuses and both the ignition and backup power wires have 12v where the plug goes into the head unit, there may be a broken connection on the connector inside the head unit.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 | |
The remote turn on is a 12V output from the JVC. Did you connect it to a 12V output from the power supply?
Tim |
#4 |
Yes all 3 12v wires are connected to the 12v power supply. I carefully removed the circuit board and tested the wiring harness. All of the 12v wires are electrically connected to the pins on the circuit board. Nothing looks burned and there isn't any smell.
#5 |
Is it possible that the detachable face isn't making good contact with the head unit?
#6 |
the contacts look clean
#8 | |
Applying 12V to that lead may or may not prevent the JVC from turning on normally. edit: pardon my simultaneous post w/DJ
Tim |
#9 |
On the face, do all of the buttons feel like they're in good working order (all click when pressed, none stuck down...)?
#10 |
None stuck. Is there something I can test for electrically?
| I2S from USB receiver to dac | morfic | Digital Line Level | 2 | 31st March 2009 07:21 AM |
| AV receiver mod | Assyst1606 | Solid State | 1 | 1st March 2007 04:48 AM |
| Hey i need help with receiver........EXPERTS HELP(two channel receiver) | Andre Baptiste | Parts | 1 | 1st May 2004 10:20 AM |
| HT without a HT receiver | paulspencer | Digital Source | 28 | 12th December 2003 08:29 PM |
| Looking for FM receiver | sobazz | Analogue Source | 8 | 31st October 2003 01:28 PM |
| Page generated in 0.09125 seconds (76.50% PHP - 23.50% MySQL) with 10 queries |
