I've got this Orion 2500D apart and I need to replace some mosfets. I can't find any data on the FB21N30D.
There are also IRF9640's on the dead channel, I'm assuming that this is the complement of the FB's ? I'm wondering about using IRF640's ? |
#2 |
Orion amp uses IRFB31N20D not FB21n30.You can use there FQP34N20C or FQP32N20C
#3 |
Replacement for IRF9640 is FQP12P20.You can replace IRFB31N20 with IRF640,but they have almost twice lower current,and higher Rds on resistance.I did that trick in JBL BPX2200.1 which uses same schematic as ORION 2500D but that will decrease capability to drive low ohm loads
#4 |
Someone sent me an amp with IRF640s in place of the IRFB31N20Ds and the IRF640s would overheat. Replacing them with the (original) IRFB31N20Ds solved that problem. Use the IRFB31N20D. The 9640 and the 31N20 are not complementary but they are the parts the amp was designed to use so that's what you should use when you replace them. Class D amps are a bit finicky when it comes to the outputs. If you ever want to experiment with different outputs, get the amp working properly with the original parts then try the subs.
http://octopart.com/parts/search?q=IRFB31N20D&js=on
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#5 |
Thanks guys, I will use the originals and I see they ARE available.
Sorry about that, I inverted the 2 and 3 when I wrote it down. My apologies. |
| Need a cross ref # | clayton | Car Audio | 2 | 27th November 2007 01:00 PM |
| Cross over help | guru_jeff | Multi-Way | 21 | 3rd October 2006 01:59 AM |
| How do you cross over really low? | Nappylady | Multi-Way | 7 | 25th June 2004 08:29 PM |
| cross over | sid510 | Multi-Way | 5 | 9th January 2004 01:00 PM |
| What do you get when you cross... | nobody special | Pass Labs | 13 | 12th October 2002 05:47 PM |
| Page generated in 0.06141 seconds (81.10% PHP - 18.90% MySQL) with 10 queries |
