Zapco Z220 no sound?
Old 21st July 2009, 03:47 AM   #11
fongman is offline fongman  United States
I'm a little confuse but, i'd test the top left and right pin. tested okay. next the right top and bottom right. and around and found none shorted.
Old 21st July 2009, 02:22 PM   #12
tsmith1315 is offline tsmith1315  United States
tsmith1315's Avatar
Amp power up fine. I measure the amp rca and got only .500v. I know i should be getting 12v, but when i apply ground to it the amp goes into overload or protection.
This statement is confusing. Could you clarify?
Tim
Old 21st July 2009, 03:26 PM   #13
The amp turns on fine without any voltage draw. I notice that the input on the RCA have low ground when the amp is trun on. I apply or put gound to it and the amp would go into overload. After 10 sec it would come out of overload. Still no sound. Thanks i hope you can help?
Old 21st July 2009, 07:11 PM   #14
tsmith1315's Avatar
The Z220 has balanced differential inputs, so the RCA shields aren't grounded...
Tim
Old 21st July 2009, 08:14 PM   #15
Thanks, do you think it will be an easy fix?
Old 12th August 2009, 05:52 PM   #16
Hi guys, i just want to update that the amp was fixed. I found out that the input RCA are bad. I resolder both side and now the amp plays fine. I want to thank those of you who help me in anyway.
PS
Perry thanks for all you time and support
Zapco Z220 no sound?Hide this!Advertise here!
HELP!! Looking for Zapco oldshoolaudio Car Audio 6 22nd June 2009 10:57 PM
zapco ag 350 genes66 Car Audio 2 28th August 2007 02:31 AM
zapco ag 350 genes66 Car Audio 29 25th August 2007 06:28 AM
Zapco Z400C4-SL scott-leanne Car Audio 23 13th May 2006 08:44 PM
Copyright ©1999-2017 diyAudio
