i took apart my stock GM radio because all the light bulbs burnt out. can anyone give me a part number for a lightbulb i can replace them with? i can even see the little fillament is burnt out in the bulbs.
#2 |
i just came back from radio shack and they have 12v / 60mA bulbs that look close and i think they will work. how do i know how many watt/amps the old bulbs in there are?
#3 |
Unless you have a magnifying lens to look at the old bulbs with to find the part numbers, you should be safe as long as they physically fit.
Don't worry... you can always turn the gain down! |
#4 |
the only numbers i can see on it are "OL 24" does this mean anything? i really would like to order the parts from mouser or another online supplier. i need about 12 of these bulbs and radio shack is charging 3$ each for these ones and i dont even know if they are going to be bright enough
#5 |
You will be fine with the Radio Shack bulbs. You need to replace all of the lamps. They may not have the same brightness of the OEM bulbs. If you replace all of them, it will not be noticeable.
If it ain't broke Don't fix it |
#6 |
but is 3$ a bulb a normal price to pay?
#7 |
Here they come 2 bulbs per pack. I think they are 2 dollars a pack.
#8 |
Are you buying the ones with the long leads? That sounds too expensive. I had to buy some a while back and don't remember them being 3 dollars.
#9 |
yes the ones with the long leads. i need to order some other parts for other amp repairs and i was waiting so i could order these along with my other parts. i just wish i could get a range of wattage/amperage that these little bulbs operate. 3$ does seen expensive to me to i figure it will be about 50$ to replace all of them.
#10 | |
here are some WAY cheaper http://cgi.ebay.com/Grain-of-Wheat-2...3A1%7C294%3A50
| Light bulbs as cathode resistors? | Jeb-D. | Tubes / Valves | 19 | 28th June 2008 01:11 PM |
| VU light bulbs? | Pbassred | Solid State | 19 | 25th July 2004 04:43 AM |
| feeding AC halogen light bulbs DC? | dorkus | The Lounge | 5 | 25th June 2003 08:28 PM |
| Page generated in 0.09898 seconds (76.32% PHP - 23.68% MySQL) with 11 queries |
