Go Back   Home > Forums > General Interest > Car Audio
Old 23rd June 2009, 01:55 PM   #1
sousmielie's Avatar
Default How easy do HIP4080AIPZ's go?
Hi all,
I've been working on a Camtec amp for a friend and would just like to know how easy do HIP4080's pop, I haven't worked on a class-d car amp that use them before. I am suspecting that it is fried as 4 of the 8 output mosfets fried creating a dead short between all 3 pins. The amp gives output after changing the fet's but it's not as loud as I would think it should be and sounds a wee bit noisy. O and the HIP4080 feels a little warm, not to hot though. The fet's are IRF1310N
Thanx
It's one of the best feelings in the world when you build something without it going up in smoke............
Old 23rd June 2009, 02:51 PM   #2
The chips sometimes fail without even having FET problems. Change it.
If it ain't broke Don't fix it
Old 23rd June 2009, 03:58 PM   #3
sousmielie's Avatar
thanx, will do
Old 25th June 2009, 09:23 AM   #4
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
When a MOSFET driver like this fails, there are very few chances for the amplifier to continue working. The failure usually results in shorted supplies.
That amplifier is probably noisy and not as powerful as expected by design. The modulator inside the HIP is noisy and most amplifiers use it instead of an external one.
Also, MOSFET drivers usually get quite hot, particularly when their outputs are not buffered and they are driving the gates directly.
I use to feel like the small child in The Emperor's New Clothes tale
Old 25th June 2009, 09:11 PM   #5
sousmielie's Avatar
This is just what I've noticed:
Supply did not short out when FET's blew, it has 8 FET's (2 FET's in parallel) on the output, 4 of which were shorted between GDS (basically the top half of the full bridge was blown). That caused the full supply voltage to be seen by the driver chip.
The amplifier isn't making nearly full power as I found out the amplifier was driving 2 DVC competition subs at 155db. And secondly it's a monoblock with a lot of features and techniques used in some of the high end car amps that is putting out as much power as say a stock headunit?
I am awaiting the new chip(s) from RS components.
Thank you
7 Easy Pieces Nelson Pass Pass Labs 86 10th January 2011 10:47 AM
Probably an easy question for some. markusb Solid State 1 22nd September 2006 08:29 AM
Probably an easy question... maguire Subwoofers 8 18th September 2006 07:23 PM
is it really this easy? MEGA-amp Pass Labs 4 2nd August 2005 01:55 AM
Easy tweak for Zen V4. Panelhead Pass Labs 7 21st July 2003 06:06 PM
Page generated in 0.08308 seconds (73.59% PHP - 26.41% MySQL) with 10 queries
