i am tryiing to fix 2 of these identical amps at the same time, i hope to save money on shipping when i order parts. they have completely different symptoms
this one can actually make sound. the problem is that it is very scratchy. i need to have the level turned almost off for it to make sound and as soon as i raise the level the test speaker goes crazy. nothing seems to be getting really hot and i cant see any burnt parts. i measured the op amps and one leg is reading 26v i figure this is probably a good place to start |
#2 |
What's the resistance from the RCA input shield to the non-bridging speaker terminals?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
23 k ohms
#4 |
You may have an open trace or a broken ground on the RCA jack. Check both. Compare it to your other one but I think it should read 0 ohms.
#5 |
yup that was it. even the super cool plasma shere took off and its better than i had expected it to be.
thank you |
| Acoustic 160 adjustments | llwhtt | Solid State | 0 | 28th April 2009 11:55 PM |
| need help on a power acoustic lt1920-2 amp | truckr012001 | Car Audio | 5 | 30th October 2008 10:58 PM |
| power acoustic amp | mike49504 | Car Audio | 1 | 5th January 2007 04:47 PM |
| Acoustic Reasearch | have' | Solid State | 3 | 20th August 2005 10:19 AM |
| Acoustic pre-amp | james27_84 | Instruments and Amps | 4 | 23rd March 2005 06:49 PM |
| Page generated in 0.07860 seconds (72.42% PHP - 27.58% MySQL) with 11 queries |
