I got one of these many years ago, but have not used it. I assumed it was a DC to DC converter that would compensate for wiring losses, but it is just a solid state switch. A conventional battery isolator can be in the feedback loop of the alternator, so there is compensation for the diode drop. It seems like the MBR70 will never bring the secondary battery up the the same state of charge as the primary due to losses in wiring and the MBR70 itself.
Has anyone used this? How well does it work? What do you think of the design? Here is the Schematic (drawn by me, so it probably has some mistakes).
Possum - the other white meat |
#2 |
It looks like it would loose ~0.6v due to the operation of Q5 but that doesn't mean the auxiliary battery wouldn't be fully charged. A lower charging voltage will reduce the rate of charge but the battery will still fully charge (12.6v is fully charged) as long as the charging voltage is ~13v.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
| Velcro as Vibration Isolator | Buckapound | Parts | 5 | 9th May 2009 07:58 PM |
| question about isolator behind transistors | Ground Zero | Parts | 3 | 28th January 2009 09:56 AM |
| DIY cable tv ground loop isolator. please help | imperfectcircle | Parts | 0 | 31st January 2007 10:13 PM |
| Looking for optical isolator for audio | FastEddy | Solid State | 0 | 27th September 2006 06:40 PM |
| PWM to mosfet - using isolator or ? | Gerlu | Power Supplies | 15 | 16th January 2005 05:44 PM |
| Page generated in 0.06181 seconds (69.05% PHP - 30.95% MySQL) with 10 queries |
