Go Back   Home > Forums > General Interest > Car Audio
Old 15th June 2009, 02:52 PM   #1
Gusel9 is offline Gusel9  United States
Default FosGate 400a4
Working on FosGate 400a4. This amp have a problem where
If I connect the remote at ones my ps amp gage goes over
20 amps, But when I top the remote and
The connect it, everything works just fine. ( everythin)
Old 15th June 2009, 09:14 PM   #2
What I think you are trying to say is: When you connect the remote wire to the remote terminal, the amp pulls current and pegs your amp meter on your power supply. And if you briefly tap the remote wire to the terminal and then connect it again, all is fine.
Is this what you are trying to say?
If it ain't broke Don't fix it
Old 15th June 2009, 10:47 PM   #3
If you apply remote voltage initially and hold it there. Will it continue to draw 20+ amps for more than 1-2 seconds?
Old 16th June 2009, 07:44 AM   #4
That's exactly right, if I leave the
remote cable on the remote connector
For more then 2 seconds My power
mosfets shorts out, also after it has
Been working fine for minutes, all I
Have to do is disconnet remote from
Remote connector for 4 or more
Seconds, reconnect againg, and problem
repeat it self. Thanks for your help.
Old 17th June 2009, 04:01 AM   #5
If you disconnect all of the speaker wires from the terminal blocks and disconnect the RCA cables, does it act the same?
Would you be able to measure the voltage at several points inside the amp?
Old 17th June 2009, 04:03 AM   #6
Default fosgate 400a4
I will like to mention that I have just add a 2
ohm resistor to the b+, and after applying
remote cable to remote connector, power
supply goes up about 2 amp, then goes all
normal.
Old 17th June 2009, 05:07 AM   #7
Yes it does do the same with or without speakers And rca
cables connected. I replece the tl494 and, The pots are all
counterclockwise, but no luck. Can this be relate to a soft
Start, or dtc condition. The 2ohms resister on the b+ does
help alot.
Ones again. thanks for your quick response.
Old 17th June 2009, 05:43 AM   #8
Was it doing this before you replaced the 494?
When you power it up and it's drawing excessive current, measure the DC voltage across the 0.1 ohm source resistors. Do any have more than 0.000v across them when it's drawing excessive current?
With the black probe on pin 7 of the 494 and the red probe alternately on pins 9 and 10, does either remain at or near ground and the other go to ~B+ (whatever that is when it's drawing excessive current)?
Old 17th June 2009, 07:00 AM   #9
I replaced the 494 thinking
It was cousing this problem.
now, I only have 1-2 seconds
to do The vol drop test to the
1ohm Resistor. any sugestion?
Old 17th June 2009, 08:03 AM   #10
If you power it up through the 2 ohm resistor and have the transistors clamped to the sink, you can take your time. There won't be enough current flowing through anything to cause any damage. The voltage across the 0.1 ohm resistors will be less than when powered directly but you should be able to read voltage across them if the problem is in the audio section.
FosGate 400a4 Gusel9 Car Audio 0 16th June 2009 04:30 PM
Rockford 400a4 problems elvisjer Car Audio 3 2nd October 2008 03:31 AM
fosgate t2's ba109296 Swap Meet 0 5th February 2006 08:37 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
