Go Back   Home > Forums > General Interest > Car Audio
Old 14th June 2009, 06:19 PM   #1
SS64 is offline SS64  United States
Default Cda-7940
I need some help repairing this Alpine 7940 that was just given to me.. It does not power on so that leads me to believe there is something wrong in the internal psu?..... The guy touched the + lead to the case.. And upon opening I find D801 blown and cracked.. Any help? or is it even worth messing with?
It isn't fun unless it can kill you!
Old 14th June 2009, 11:47 PM   #2
If D801 is located very near the plug, it is the reverse polarity protection diode. If it is visibly damaged, the radio was overfused and connected with power and ground reversed. Simply replace the diode and repair the burnt trace between the plug and the diode.
If it ain't broke Don't fix it
Old 15th June 2009, 03:45 AM   #3
Yes it is the reverse polarity diode that is blown but I cannot find any visibly burt parts or traces... and it still doesn't light up...
Old 15th June 2009, 04:08 AM   #4
I just took apart the external dc to dc converter and no burt parts there ether... I also just replaced the diode with no change..
Old 15th June 2009, 04:27 AM   #5
is there voltage getting to the diode and to the inductor and to the output chip?
Old 16th June 2009, 03:17 AM   #6
yes I am getting voltage though the plug and to the inductor.. And this unit is a pre out only head..
Old 16th June 2009, 06:01 AM   #7
Is there an IC mounted to a heat sink or to the back or side cover of the unit. If so, what is the number on the chip? And what is the location number, IC XXX
Old 16th June 2009, 11:35 PM   #8
No there is no IC... I see where it would go.. but this unit is a dead head and has 3 preouts.. and I do have voltage to where the IC would be....
Old 18th June 2009, 01:18 AM   #9
I am not talking about the output Chip. That unit may be too old, but there is a multiple voltage regulator on some of the newer units. HA13165 is the number. I have replaced a couple of them. If your unit has this part, I would begin checking there.
Old 24th June 2009, 10:50 PM   #10
Default CDA 7940 parts replacement list from PacParts Inc.
Here are a few items that PacParts Inc. stocks for your Alpine CDA 7940. I hope this helps. www.pacparts.com
01:ANTENNA PLUG 1:01T15513W23
02:WIRE HARNESS 2:01T75469W21
03ETACHABLE FACE ASSY 3:01V14300Y78
04:MOTOR, LOAD 4:01V73300W33
05:MOTOR, SPINDLE 5:01V73300W35
06:MOTOR, SLED 6:01V73300W38
07:FRONT ESCUTCHEON 7:13C10783Y01
08:NOSE BOTTOM 8:13D10486Y01
09:NOSEPIECE 9:13T15458Y02
10:CARRYING CASE 10:15D10867Y01
11:MOUNTING SLEEVE 11:15D50406W01
12:TRIM RING 12:33C10618Y01
13:CONTROL KNOB KIT 13:36B10628Y01
14:VOLUME CONTROL 14:40T45670W05
15ISPLAY 15:65T15625Y01
16:FL TUBE LOC# CFL401 16:65T25014Y02
17:LAMP PL401/402/405/406 17:65T75233W01
Page generated in 0.08863 seconds (81.92% PHP - 18.08% MySQL) with 9 queries
