Modified Sony XM-554ZR power amplifier for 6 Volt system. The modification was tested form 5 to 7.2 volts, it sounds fantastic.
Connect the ignition switch or a toggle switch to the remote terminal. The head unit doesn’t have power until the amplifier is on, so you can’t use the remote form the head unit. The 12 V memory output is on all the time for the head unit memory. The head unit 12 V output will also power an iPod/MP3 12 V adapter or Satellite Radio. Now you can have an awesome sound system in your 6 volt. Specifications http://www.thesamba.com/vw/classifie....php?id=796241 |
#2 |
Fixed the link:
6V Sony Power Amp I must say that I'm quite grateful that I drive a "Boldly Modern" 1957 Ford panel delivery that came from the factory with 12 volts, so newfangled gadgets like "FM Radio" or DVD players with drop-down LCD displays can install with no problems. |
| 6 Volt Sony Power Amplifier | WSJ | Vendor's Bazaar | 0 | 8th June 2009 03:11 PM |
| Sony TA-N55ES power amplifier | mikeks | Solid State | 42 | 5th September 2006 04:53 PM |
| Page generated in 1.82967 seconds (3.53% PHP - 96.47% MySQL) with 10 queries |
