I had a 60 dsm given to me and it has p80nf55-06 for the ps fets
and they heat up fast. The bias is turned all the way down after I thought that might cause it. Are the 68 ohm gate resistors fine with those fets? The amp works fine other than that. |
#2 |
Do they heat up at idle or only when it's driven hard?
Were they clamped to the heatsink when they were heating up? It is possible that the gate resistance is too high. These input capacitance of those FETs is significantly higher than the originals (likely IRFZ40s or BUZ11s).
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
It heats up at idle , fets were clamped .
the 2 caps by the ps fets are getting hot also at idle. |
#4 |
Do you have any resistors between 33 and 47 ohms you could install in place of the 68 ohm resistors?
If so, try it to see if it makes a difference.
#5 |
replaced them with 47 ohm and seems to be ok .
This amp was a real hack job , parts unsoldered inside the cover , atleast i didn't pay anything for it . Thanks for the help! Ben |
#6 | |
Don't worry... you can always turn the gain down! |
| Selling a punch 250a2, old punch 75, and ppi epx 205 on EBAY | ppia600 | Swap Meet | 0 | 23rd February 2008 01:17 AM |
| My experience: the cheap punch set VS Greenlee punch | vax9000 | Tubes / Valves | 5 | 21st July 2006 07:52 PM |
| SI T-amp warm-up? | irss | Class D | 3 | 8th April 2005 11:40 PM |
| only reading cds after warm-up | hiwiho | Digital Source | 7 | 6th October 2004 06:22 AM |
| My amp gets warm... | Jye | Multi-Way | 6 | 21st November 2003 11:53 PM |
| Page generated in 0.07972 seconds (83.54% PHP - 16.46% MySQL) with 10 queries |
