Has anyone ever performed a permanent modification to the gain sensitivity switch in a Reference 700s? Right now it seems as if my left channel is stuck in .2 to 2v whereas only the right channel responds to the .5 to 5v setting.
If I push the switch to the left, both gains respond accurately to the .2 to 2v setting, but when I slide it to the right, only the right channel responds to the higher voltage sensitivity. Sadly, the switch worked the last time I used the amp. |
#2 |
You can clean the switches. If it's the type of switch that moves a metal bridge/slide from one set of contacts to the other, contact cleaner and moving it from one position to the other will generally make them reliable.
If it has the other type of contacts that work more like a toggle switch internally, you'll have to disassemble the switch to clean the contacts (if you want it to be reliable).
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Thanks Perry, I will try the easy solution first. Lately, I have been all to eager to tear things apart.
#4 |
JandRelectronics on ebay has the switch sets for sale. But cleaning does work sometimes. I also find the housings get lose and a complete removal and rework will bring them back, but at that point just dropping a new one in also works well...
#5 |
I've tried spraying WD40 into the switches, moving it several times quickly then blasting it with compressed air (for an air compressor) to remove all the WD40 and the dirt along with it. works well for me.
| Modify a Soundstream Reference 700s | 0ldSch00lf00l | Car Audio | 3 | 28th November 2008 08:31 AM |
| Soundstream Reference 604 | Herb009 | Car Audio | 7 | 9th January 2008 08:52 PM |
| Soundstream Reference Class A 6.0 | audiobahnkid592 | Car Audio | 0 | 9th January 2008 12:57 AM |
| SoundStream Reference 604 help | audiobahnkid592 | Car Audio | 12 | 30th June 2007 09:49 PM |
| soundstream reference 604 | Bgun | Car Audio | 9 | 7th October 2006 04:24 AM |
| Page generated in 0.07657 seconds (73.72% PHP - 26.28% MySQL) with 10 queries |
