help with my Xtant 1001d
Old 28th May 2009, 03:45 AM   #1
91h22a is offline 91h22a  United States
Default help with my Xtant 1001d
Hello all I have an xtant 1001d amplifier and it has very low sound output so I determined this must have something to do with the muting circuit. So i have traced the remote lead and found what appears to be a missing capacitor in location C53. The leads remain and look like the cap has broken off.
Now I purchased this amp broken (all jumpers in correct locations) and as all of you know there is really no help when it comes to xtant. So I hope to get some good advice here from some repair veterans.
I am an electronics tech but only for about a year and I only work on lcds plasmas blu rays but never without schematics! So my limited experience leaves me lost and I have all but begged (well maybe a little) Xtant for schematics. Any help would be greatly appreciated and any advice on this amp would also be welcomed.
I am determined so no suggesting sending it to a repair facility
Old 28th May 2009, 09:20 AM   #2
Perry Babin is offline Perry Babin  United States
Are the gain jumpers in the +20dB position?
Are the gain pots at the maximum position?
With 1v in, what is the output voltage on the speaker terminals?
Old 29th May 2009, 03:22 AM   #3
Mr. Babin, thanks for the prompt response. I hooked a 1v signal to the amp with the signal jumper at the +20db setting and the gain turned to max and got something like 1.5volts at the speaker terminals. Then I did some looking all over the amp and found the large iron core transformer to have 6 out of 16 (or 20 i am not certain) of the legs broken just slightly so the only way I found them were to pry them away from the pcb. So I cleaned off the coating and soldered the broken leads and now i am seeing something like 44 -55v (depending on the gain). So Mr. Babin what if any suggestions do you have...the amp seems to be producing much more power but I am still curious to hear your thoughts before throwing it into the car. Again thanks for your expertise and assistance.
David
Old 29th May 2009, 12:38 PM   #4
It sounds like you found the problem. Reinstall it to see if there are any other problems.
Old 29th May 2009, 01:03 PM   #5
Westerp is offline Westerp  Netherlands
Westerp's Avatar
I would hook it up to a couple of resistors around 8 ohm 30 watt with a
small speaker and 50 ohm in series across then feed it a signal first. Putting it
back without being sure it works as intended could cost you your speakers.
That voltage at the output could be anything.
http://tda1541a.com The Final List
Old 29th May 2009, 03:38 PM   #6
It appears to be working. With 1v in, it was producing 40+v on the outputs.
Old 30th May 2009, 07:10 AM   #7
Thanks gentleman for your input!
Mr. Babin thanks to you especially because I have your DVD for Basic Car Electronics and it certainly helped me with this endeavor.
The amp seems to be working well after a 10hr burn in at medium levels and I am happy to say I feel confident enough to incorporate this amp into my vehicle.
Thanks again and I hope I can help you in return sometime.
David
Old 21st July 2009, 04:21 AM   #8
darylf is offline darylf  United States
Hey do you still have your x1001d? If so you could you look up a couple of vaules for me?
thanks
Old 21st July 2009, 01:57 PM   #9
I do. Let me know what you need and I will get back to you as soon as I can.
Old 21st July 2009, 09:55 PM   #10
Great, Thank you so much.
Im in need of these values.
Q25 last on on the top row of fets.
I need to know what Q35 is, its about 3 inches below to the left of Q25
and Q3-11. left side of the fets. I have IRFz44N, but Im not sure they are the correct fets.
Also my board is PCB-1001d
And has no fans on the heat sink.
thanks again.
Daryl
help with my Xtant 1001dHide this!Advertise here!
xtant 604 x mike49504 Car Audio 8 29th November 2008 08:00 AM
Xtant X1001 shagone Car Audio 11 15th April 2008 12:28 AM
FST ~~ XTANT 4.4 -- 4 channel -- like new ~~ Livin Swap Meet 7 5th March 2008 10:23 PM
xtant 1001d low power Bgun Car Audio 0 22nd November 2006 05:50 AM
Xtant 1001d blowing fuses torxim Car Audio 8 27th February 2005 07:33 PM
Copyright ©1999-2017 diyAudio
