Go Back   Home > Forums > General Interest > Car Audio
Old 20th May 2009, 02:03 AM   #1
Default bostwick da1200.1hc problem
when i give the amp a hot and a ground , it does nothing... when i hook the remote wire to it, it pulls a constant 20 amps of juice from my power supply... the power supply transistors get rather hot...
the amp does not power on at all...it doesnt have a protect light, just a green led that does nothing...lol
actually i have 2 of these amps doing the same thing...
i replaced the hip chip to no avail... changed the power supply transistors and gate resistors...does the same thing...
the transformer doesnt have a short in it...
ive tested the gate drive transistors, and they are reading two reading of 0.678v , so they test good...
ive changed out the tl949 pwm ic chip.....still pulls 20 amps....
ive taken out the rectifiers. it still pulls 20 amps
the outputs and not shorted.....
ive pulled all the caps on the power supply side, they are good...im going to pull the others near the outputs next..
what is the black rectangle thing in the middle of the amp? it has a row of 8 or so pins right under it....
pics:
Old 20th May 2009, 02:26 AM   #2
If it only pulls current after remote voltage is applied and it pulls current with the rectifiers out of the circuit, it likely has either a defective drive circuit or a shorted transformer.
How did you check the power transformer to determine it wasn't shorted?
While the power supply FETs were out of the board, you should have checked the voltage on the gate pads for the PS FETs. If you pull the FETs again to check it, it should be ~5-6v DC on all of the PS FET gate pads.
The black box is the protection module.
Old 20th May 2009, 04:58 AM   #3
i checked for continuity from one side of the transformer to the other....
and if i put just a hot and a ground to the amp , i dont see any voltage on the secondary side..
is there another way to see if the transformer is shorted?
i took the ps fets back out , and i have 5.99v on the gate resistors..
Old 20th May 2009, 05:08 AM   #4
Checking from primary to secondary only tells you if it's shorted from primary to secondary. If you have windings shorted from primary to primary, the meter won't show it. You either have to ring it (with an inductor ringer) or you have to drive it with a known good driver circuit.
Do you have the same DC voltage on 'all' gate pads for the PS FETs?
Old 20th May 2009, 05:16 AM   #5
yes, all the gate pads have a good 5.9 voltage
Old 20th May 2009, 05:20 AM   #6
Do you have a large (20 watts+) 2 ohm current limiting resistor?
Old 20th May 2009, 05:25 AM   #7
no i dont.... are they the big white tall square resistors?
Old 20th May 2009, 05:34 AM   #8
They can be any shape. Tomorrow, go to Radio Shack and buy 4 of the 271-120. Connect them in parallel.
Reinstall the FETs and clamp them to the heatsink. Connect the paralleled resistors in series with the B+ line feeding the amp.
Power up the amp and twist (push, pull...) the transformer. if it's intermittently shorted, the voltage will be dragged down when it's shorted and will go up to ~12v when the short is broken (when you twist the transformer).
Old 20th May 2009, 01:49 PM   #9
maydaydeejay's Avatar
Send a message via Yahoo to maydaydeejay
It seems like an another relay, but this one is for output voltage from inverter.
The "main" relay is located near speaker output... and really this black thing looks like one of them to me.
It may B poss that it has some shorts or so.
regards
mark
Old 21st May 2009, 07:04 AM   #10
i got the resistors...
after twisting and pulling on the transformer , the amp powered up and started producing sound..
both of the amps had shorted transformers...it must be a bad design or something...
what do i need to do to the transformer now that i got the short out? will clear epoxy work to keep it from moving around again?
Hum problem sonata149 Tubes / Valves 0 28th February 2009 08:35 PM
mtx amp problem [[help!!]] fuzzypinkhat45 Car Audio 3 8th July 2008 05:34 AM
CDM 2/29 Problem – HELP! Bassivus Digital Source 29 23rd December 2007 10:00 AM
FRD/ZMA Problem Twisted85 Multi-Way 5 4th December 2006 01:19 PM
GC amp problem Jamh Chip Amps 30 6th April 2004 02:50 PM
Page generated in 0.09915 seconds (80.42% PHP - 19.58% MySQL) with 10 queries
