Need help troubleshooting whine in speakers
Old 17th May 2009, 06:59 AM   #1
roger2 is offline roger2  United States
Default Need help troubleshooting whine in speakers
Hi all. I'm trying to solve a mystery. Whine in speakers of my car system, even when the engine is not running. When the engine is running the whine fluctuates, pitch goes higher, when the engine RPMs increase.
This is not a new installation. The system was fine for about a year with no problems. Nothing has been changed or added.
I have already done the basic troubleshooting: I checked all connections. Grounds are all good. Swapped out the amp and the problem didn't change. Swapped out the RCA cables and no change. Removed head unit and ran a seperate ground wire to it, no change.
However I did discover how to make the whine go away. There is a 4-prong connector plugged in to the alternator - when it is un-plugged the whine goes away. (picture of the connector below)
The system has no whine when this 4-prong connector is unplugged.
When this connector is plugged in there is no whine when the key is in the "Accessory" position. But when the key is in "ON" position (with engine not running) the whine comes back. And finally, when the engine is running the whine changes with engine speed.
At this point I suspect a problem in the car electrical system and not in my head-unit or amps. But I do not know enough to go further with out some help
It is interesting that having the key in "Accessory" position yields no whine but moving it to "ON" makes the whine appear.
Any thoughts?
Old 17th May 2009, 10:42 AM   #2
I Am An Idiot is offline I Am An Idiot  United States
Try this
If it ain't broke Don't fix it
Old 18th May 2009, 12:47 AM   #3
Default that was it
Thanks I Am An Idiot for the link. There was about 200 ohms between the HU case and the RCA shields. I fixed it as shown in the web page link.
And props to Perry Babin for offering such a useful and informative web site.
And if anyone was wondering, yes my HU is a Pioneer.
Working fine now and sounding good. I missed my car system but it is back
Old 18th May 2009, 02:11 AM   #4
jol50 is offline jol50  United States
Must be something in the car makes noise with the key on. It will pick up noise from anything with no RCA ground. Mine still working ok but only had two different amps on it so far. (880prs) Planning on testing more amps though so hope it holds out.
Old 19th May 2009, 12:26 PM   #5
Dan2 is offline Dan2  South Africa
well what would come on with the engine off and ignition ON??? Don't fuel injected cars have an electric fuel pump that come on before the engine starts??
Yes i must also say props to Perry for his site, my Pioneer HU gave me engine noise before i used Perry's fix
Old 19th May 2009, 05:22 PM   #6
Most fuel pump come on and shut down if the engine is not started, but other things are on like ECU, heater fan, all the sensors for gauges/emissions/etc.
Need help troubleshooting whine in speakersHide this!Advertise here!
Advice needed on engine whine in speakers DeadSpeaker Car Audio 13 1st May 2009 07:57 PM
Ground from Deck makes speakers whine metaverse Car Audio 4 16th January 2009 10:02 PM
Need HELP with alt whine pityocamptes Car Audio 105 4th December 2007 12:12 AM
Engine whine feelinhipp Car Audio 3 13th March 2004 05:53 AM
Can someone help me with alternator whine? Timbers Car Audio 14 23rd February 2004 05:14 PM
Copyright ©1999-2017 diyAudio
