Help with an amp, turns on but no sound - Page 3 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 2nd May 2009, 09:14 PM   #21
Pin 3 is being driven high. Does it go back to pin 1 or pin 7 of the 8 pin IC (via resistors, possibly)?
If so, post the voltages on that IC also.
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
What's the number on the 8 pin IC?
It may also go to a PNP transistor (likely small, black, shaped like the letter D).
Old 2nd May 2009, 09:38 PM   #22
4558D
Pin 1: 10.34
Pin 2: 0.0
Pin 3: 5.62
Pin 4: 0.0
Pin 5: 1.42
Pin 6: 5.03
Pin 7: 1.42
Pin 8: 11.25
Jensen KA 4660HLx 4ch 540W
Pyramid PB675 4 ch 800W
Old 2nd May 2009, 10:04 PM   #23
Does it appear that pin 1 of the 4558 is connected to pin 3 of the 494 (via diodes, resistors...)?
Old 2nd May 2009, 10:25 PM   #24
from what i can see, i dont think so.
Old 2nd May 2009, 10:52 PM   #25
Earlier, you removed at least one output transistor. Did you pull it to check it? Did you check the output transistors to determine if any were shorted?
Old 2nd May 2009, 11:37 PM   #26
I removed it to check it and to see if the reading changed once it was out. According to the data sheet it is fine.
I wanted to check the diff to a working amp, and my sony had a reading of 19 Volts on the #2 pin on the output transistors.
And I thought about putting the one transistor in place in a good amp, but dont want to break a good amp.
Old 3rd May 2009, 12:32 AM   #27
You're sure that none of the output transistors are shorted?
Does the amp have a protect LED?
Old 3rd May 2009, 01:20 AM   #28
it has a protect led, but not sure if it works, i dont know how many volts it is so i can test it.
Old 3rd May 2009, 01:42 AM   #29
Are you sure that none of the output transistors are shorted?
Old 3rd May 2009, 01:47 AM   #30
not sure, but im going to take this amp as a learner and take things off the board until i find a bad part(s).
If it was an expensive amp, I would continue.
Thanx for your help. (And will post if i find the problem).
I dont knw if u seen my other post on my source unit, the cd doesnt spin anymore, now I do want to fix that. - Car stereo doesnt want to play CD's anymore.
Precision Power PC6600.2 Amp turns on then immediately turns off. Need help! autolink Car Audio 4 15th March 2009 03:12 AM
Which turns you on? nl Digital Source 0 30th July 2004 11:50 PM
MTX Amp Turns on- Dirty output fixitalldan Car Audio 5 9th July 2004 03:06 PM
Pioneer cd player, turns on but no sound? the bass master Car Audio 0 7th February 2004 05:41 PM
Copyright 1999-2017 diyAudio
