#11 | |
OK u are right, so power didnt go from one end of the straight one to the other. So I took it off the board it one end wasn’t soldered anymore, so I re-soldered it in. And here is the is what I got off of the 4 transistors: the first two: Pin 1: 0.0 Pin 2: 12.0 Pin 3: 0.0 the second two: Pin 1: 2.33 Pin 2: 2.64 Pin 3: 2.33 |
#12 |
What are the numbers on the faces of these 4 transistors?
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#13 | |
#1 - LRF**4 - could not read good - even tried #2 - LRF**4 - magnifier with light. #3 - C2500 #4 - BY028E |
#14 |
Do the transistors look like they are the original parts?
Are you looking at the 4 on the left (two top, two bottom)? Could the numbers be IRFZ44? Sometimes, if you rub some of the white heatsink compound on the face of the transistor, it makes it easier to read the numbers. With the amp powered up and the black probe on a non-bridging speaker terminal, what is the DC voltage on the center legs of the large output transistors?
#15 | |
ok Here is how i was #ing them, tell me by the # on the pic so we are on the same page(transistor). Thanx D |
#16 |
Oh and i did reinstall the # 10 transistor.
#17 |
1, 2, 5 and 6 are the power supply FETs (from what I can tell).
3 and 4 are the rectifiers. 7, 8, 9 and 10 are the output transistors. When you measure the voltage on 1, 2, 5 or 6, you need to have the black probe on the chassis ground terminal. When you're measuring the voltage on the rest of the transistors/rectifiers, you need to place the black probe on a non-bridging speaker terminal.
#18 |
ok new readings.
1 - 2 - 5 - 6: Pin 1: 0.0 Pin 2: 12 Pin 3: 0.0 3: Pin 1: 0.0 Pin 2: 0.66 Pin 3: 0.0 4: Pin 1: 0.0 Pin 2: 0.31 Pin 3: 0.0 7 - 8: Pin 1: 0.28 Pin 2: 0.66 Pin 3: 0.09 9 - 10: Pin 1: 0.28 Pin 2: 0.31 Pin 3: 0.28 |
#19 |
Post the DC voltage on the pins of the TL494. Black probe on chassis ground. Amp powered up.
Pin 1: Pin 2: Pin 3: Pin 4: Pin 5: Pin 6: Pin 7: Pin 8: Pin 9: Pin 10: Pin 11: Pin 12: Pin 13: Pin 14: Pin 15: Pin 16:
#20 |
Ok the # on that chip is KIA494P
Pin 1: 0.01 Pin 2: 4.9 Pin 3: 4.95 Pin 4: 0.20 Pin 5: 2.0 Pin 6: 3.54 Pin 7: 0.0 Pin 8: 12.1 Pin 9: 0.0 Pin 10: 0.0 Pin 11: 12.1 Pin 12: 11.24 Pin 13: 5.03 Pin 14: 5.03 Pin 15: 5.03 Pin 16: 9.73 |
| Precision Power PC6600.2 Amp turns on then immediately turns off. Need help! | autolink | Car Audio | 4 | 15th March 2009 02:12 AM |
| Which turns you on? | nl | Digital Source | 0 | 30th July 2004 10:50 PM |
| MTX Amp Turns on- Dirty output | fixitalldan | Car Audio | 5 | 9th July 2004 02:06 PM |
| Pioneer cd player, turns on but no sound? | the bass master | Car Audio | 0 | 7th February 2004 04:41 PM |
