I am thinking of using IRFz44's in the power supply in a 2nd gen 250 instead of 80n06's. Are they ok to use? Do I need to change the gate resistors?
It isn't fun unless it can kill you! |
#2 |
They probably have 10 ohm gate resistors. If so, you don't need to change them. The Z44s are rated for significantly less current than the 80N06.
Do you know if the 80N06s are the original parts?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
No it had 60n06's but I have used the 80n06's in the past for replacements. I have a 100 z44's sitting here and I want to use them for something...
#4 |
If it's your amp, you could use the Z44s. If it's for a paying customer, I'd use the original or something better.
Unless you're going to run it into the lowest rated ohm load, it probably won't make a difference.
#5 |
Alright thanks Perry. I know you recommend IRF3205's but I cant find them on the cheap. The local place here charges a little over $3 a piece for them and they don't give quantity discounts.
It is a customers and I would Like to use the 3205 so where can I find them the cheapest?
#6 |
Try THIS.
#7 |
Thank you Perry. Your always very help full and I appreciate it.
#8 |
Ive also found that allied electronics has them for a lil cheaper. Its one of the companies i use for parts orders hope this helps
www.aliedelec.com |
#9 |
sorry the website is www.alliedelec.com
#10 |
Activeparts on flea-bay also has them for way less then $3.00 each and always available it seems. good luck
| Replace IRF540 in IRFZ44 | Dj BASS AMP | Solid State | 10 | 29th August 2011 04:11 PM |
| irfz44 | rodolfo | Solid State | 9 | 18th April 2005 08:31 AM |
| how much power can i get fro IRFZ44? | Astro Power | Solid State | 26 | 4th February 2005 02:12 PM |
| Aleph With IRFZ44 | Jay | Pass Labs | 7 | 24th February 2003 10:59 AM |
| Using IRFZ44 in place of a IRFP044 | Nicwix | Pass Labs | 6 | 19th July 2002 12:31 AM |
| Page generated in 0.10864 seconds (80.58% PHP - 19.42% MySQL) with 10 queries |
