#21 | |||
team_innovative:
What is impractical about it? Quote:
Never say never about things car audio.
Tim |
#22 |
Sorry all, have not had alot of time to update on this set up.
Done! What I've done, I built a box, ran the three subs in parallel (1.33 Ohm to amp), bridged. It sounds amazing, lots of bass, it is working perfectly. But obviously I am pushing the amp to its limits. I'm pretty sure amp is running alot hotter than it should be. Tim
#23 |
What model amplifier are you using?
Don't worry... you can always turn the gain down! |
#24 |
I had four DVC subs running coils in series and then parallel, so a 2 ohm load x 1 channel. I swapped another amp in that would only run 4 ohm x 1 for sub, so I wired them pairs in series to get 8 ohms. The subs are all IB in a back seat baffle, so might not be good to run only half of them but I didn't try it since double the drivers should give me around the db of half the wattage anyway IIRC? It has 150rms into 4 ohms I don't know into 8. It works for normal listening, it will not go real loud. But I imagine four 12s of cone area helps output on modest power. The previous amp was 420rms into 2 ohms and shook the car pretty good, I just wanted to test this one out mostly for the sound in the highs and to see if it worked right since it was supposedly broken and does not seem to be after month plus of use. But it must be putting out around 25rms per sub, something to laugh about, however it does work well up to maybe max volume a good stock system would have except it gets pretty deep doing it.
Yeah I would pick up a 1 ohm stable sub amp. I have a little insignia I got cheap that is 400rms @ 1 ohm I think, cheap amp but not tried it yet. It seemed to work well into a 2 ohm sub on the bench. |
#25 |
Amp, Pheonix Gold Sapphire 3.0:
http://ampguts.realmofexcursion.com/...pphire_SA3.0X/ Bridged, it's stable at 4Ohm: 1 x 220W @ 4 ohms bridge (12V) My three subs in parallel are at 1.33Ohm. Heck of alot of bass, and again, the only issue I can see is if I pump the volume loud for too long, due to the heat from the transistors to the heatsink. So for now it works as I need it. Hoping to maybe get another amp for the subs, and use this amp to power the mids and other speakers when ready. Tim |
| series or parallel? | medicman | Tubes / Valves | 5 | 22nd January 2009 04:42 PM |
| Series vs parallel? | legendaryfrog | Full Range | 5 | 14th December 2006 02:50 PM |
| series vs parallel SPL? | 2litre | Multi-Way | 16 | 22nd February 2006 09:58 AM |
| Can Speakers be Wired Out of Phase in Series | ralph-bway | Multi-Way | 5 | 7th May 2005 02:33 AM |
| Page generated in 0.08881 seconds (77.57% PHP - 22.43% MySQL) with 10 queries |
