Go Back   Home > Forums > General Interest > Car Audio
Old 24th April 2009, 10:07 PM   #1
Default JL 500/1v2 amp Burned Resistors
As title says, i have burned the resistors and Transistors on the Power side. I've ordered the replacement transistors and am stuck on the resistors. Can someone help me with ordering the correct resistors? The ones on the amp are burned up and am not able to read the color value. Any suggestions?
Old 24th April 2009, 10:42 PM   #2
I haven't repaired a V2 but the power supply gate resistors are likely 47 ohm, 1206 (size) components.
Mouser:
71-CRCW120647R0FKEB
If you're not sure of the size of the originals, use the lead spacing of the SMD ICs. The one on the left is 1206. The one on the right is 0805.
http://www.bcae1.com/temp/ttIMG_7796b.jpg
Old 25th April 2009, 12:30 AM   #3
This is the type of resistor that i'm looking for...I hope i'm not reading your post wrong. The link to the picture you posted looked like a flush mount resistor and that's not the one that is burnt on my amp.
http://209.3.61.141/iecnet/images/jpeg/RE47.jpg
Thats what the resistor looks like that is burnt up on my amp.
I hope i dont sound like an idiot.
also, Thanks for replying!
The resistor is directly infront on the Transistor...I wish i could put a picture of the items that are bad up...but there are no pictures of the JL's internals online.
Old 25th April 2009, 02:06 AM   #4
When you say the power side, are you talking about the power supply section or the audio section? What was the original number of the transistor(s) that were burned up?
If it ain't broke Don't fix it
Old 25th April 2009, 03:28 AM   #5
When I said power side...I ment the side with the power terminals...however, Im pretty sure it's the "audio" transistors that are bad. The transistor numbers are IRFZ44N I think...I'm at work and recalling from memory. I was able to find the correct replacement for them, just not sure what the resister values are.
Old 25th April 2009, 08:15 AM   #6
The Z44Ns are the power supply FETs.
The following resistors are through-hole components similar to the one you posted. The top one is a 1/8w. The other is a 1/4w. Look at the dimensions and order the one that fits your board.
Mouser:
299-47-RC
291-47-RC
If these resistors connect to the gate leg of the IRFZ44s, the 47 ohm resistors will work.
Old 25th April 2009, 08:04 PM   #7
This is a picture of the board and im pointing to where they are on the board...I'm pointing to transistor on this one.
Old 25th April 2009, 08:04 PM   #8
...and here is a picture of the Resistor.
Old 25th April 2009, 08:04 PM   #9
Are most of the amplifier resistors 5% tolerance or 1%?
Old 25th April 2009, 08:04 PM   #10
Ok, so i just took out the resistors from the board...they are burnt but would the reading from my meter be different if they were burnt? I'm getting readings randing from 70 ohms to 96 ohms from the different resistors i took off.
Here is a more detailed pic of the resistors on the board.
Resistors burned up on Tripath 2022 kit ozerik Chip Amps 1 3rd August 2009 11:19 PM
kicker 352xi resistors across output burned, what resistance? ppia600 Car Audio 2 19th August 2007 02:45 AM
ppi pc21400 resistors burned out focuspower1320 Car Audio 2 23rd August 2005 07:18 PM
Cambridge Audio A4 Burned resistors ChrisW Solid State 0 2nd May 2005 04:55 AM
Page generated in 0.09401 seconds (79.04% PHP - 20.96% MySQL) with 11 queries
