help me with my amplifier
Old 27th April 2009, 03:35 PM   #11
Perry Babin is offline Perry Babin  United States
You can check to see if they're shorted in the circuit. That's the most common failure mode.
Old 28th April 2009, 04:21 AM   #12
pong is offline pong  Philippines
checked the IRF640's today.. its A ok.
o btw i just remembered my DC Power supply only runs at 1.23mA(i checked it last night with my dvom) i was just wondering could it be the PSU cant turn on the circuit thats why it turns to protect mode???i'll try to borrow from my friend tonoght see what happens.
any other tests that i can do?..i was worried i'll fry the fets again.
Old 28th April 2009, 08:36 AM   #13
luka is offline luka  Slovenia
luka's Avatar
why the hell did you buy SLA1500???? this is not a 1500w amp, more like 1200w if that, has pretty much bad sound, but is "pretty" cheap...fun first amp, until you have something else, which is a lot better
I have schema for it, if you want... It is from some model before, but at least you have latest model, I think it is still
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 28th April 2009, 10:25 AM   #14
pong:
You should get a proper power supply before you do any more troubleshooting. If the supply is rated for more than 5 amps, insert a 10 amp fuse in the B+ line before you power up the amp. Have all transistors clamped to the heatsink to prevent them from overheating if there is a problem causing the amp to draw excessive current.
The protection LED generally only illuminates when there is a problem in the audio section (and sometimes during the turn-on mute delay).
luka:
Does the schematic show the circuit for the audio driver board? I'm looking for the part number for the 14 pin IC.
Old 28th April 2009, 10:28 AM   #15
ohh... i think they have perfectly the same schema and layout..weird..this amp is a sound magus x1502..yeah pretty quite cheap amp.. but pushes very good though.
can i have a copy of your schema?this would be a great help!thanks luka.
my bad should have invested on a good ac-dc supply.
i'll be borrowing from a friend tonight..hope some good would turn out..
Old 28th April 2009, 11:37 AM   #16
luka's Avatar
Originally posted by Perry Babin
luka:
Does the schematic show the circuit for the audio driver board? I'm looking for the part number for the 14 pin IC. [/B]
No Perry, it does not [at least I think so, don't remember anymore], I would need to contact guy in charge for this amps here, that is what Company Sinus live said to me
Can't you read what that part is, like with UV or something like that?
I FEEL SLOVENIA
Old 28th April 2009, 11:45 AM   #17
luka's Avatar
Hmm diffrent name but same same same board LOL
1
2
3
4
Versions of SLA, bottom looks just like yours
Click the image to open in full size.My amp, when I had it
I FEEL SLOVENIA
Old 28th April 2009, 01:00 PM   #18
The top of the IC was ground too deeply on all of the ones I've seen.
Old 28th April 2009, 01:30 PM   #19
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
1
2
3
4
that's because only one company made those. Sound Magus is the house brand the company used for their own amps. but they still make amps for others.
Old 28th April 2009, 02:32 PM   #20
redhorseaudio is offline redhorseaudio  India
Hi LUKA,
Which glue arround the toroid transformer used ? Because this is very helpful to absorb to socks when the car running on bad roads
Thanx[IMG]Click the image to open in full size.[/IMG]
ssmir
help me with my amplifierHide this!Advertise here!
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 4 14th February 2018 05:11 PM
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
