Go Back   Home > Forums > General Interest > Car Audio
Old 20th April 2009, 06:54 PM   #1
jol50 is offline jol50  United States
Default Amp power supply questions, attributes
I wondered if someone who knows could summarize in general what one might recognize looking at a power supply in an amp. I find bits and pieces here and you can only tell so much by looks, but thought it may help to know if there are some generalities or 'rules of thumb' that apply?
For example I have a late 90s MTX (USA made) with 6 PS mosfets that is rated at near double the output of amps with a similar PS and similar age. Since faster (like many newer amps) operating PS are smaller, were they just ahead in technology? Are they running it closer to its limits? Better components? A combination makes it hard to tell by looks alone? I never heard of MTX over rating their output far as I know.
Some PS you can see the toroid core, others have the maximum amount of wire wound on them....does that tell anything important? Are dual toroid just a way to use lighter components on the board and/or cheaper than a single large one? Some older amps did that some not, now I see newer cheap amps doing it. Most of the big oldest old school amps seem to have used one large one.
Or am I just barking up a dead tree and there are many combinations that will produce a good PS to fit a particular situation?
Old 22nd April 2009, 05:37 AM   #2
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
The number of MOSFET pairs does not tell much because you can find them with Rds-on as high as .04 ohm and as low as .004 ohm. Cost reduction dictates the use of more devices having higher Rds-on most times. They use to buy huge lots of old surplus MOSFET...
Also, the quality of the switching circuit dictates how close to their ratings the MOSFET can operate reliably. For example, I only need a pair of IRFZ48V for 2x150W and I have even got 72A continous from a pair of these (push-pull, 50A rms per part).
The size of the transformers and style of the windings does not tell much either. You would have to measure winding resistances and leakage inductances in order to compare their grade of optimization. Note that to compare leakage inductances from different PSU they have to be multiplied by the switching frequency first.
I like small cores with 5 or less primary turns. These are operated around 50Khz. Bigger cores with more turns are usually operated at 25Khz.
I use to feel like the small child in The Emperor's New Clothes tale
Old 23rd April 2009, 01:50 AM   #3
Thank you for the insight Eva.
I'll have to read up on leakage inductance, might be a while before I design a PS but any info helps. Sounds like some type of testing would be a better way to identify how well a PS works.
It seemed quiet here and I was curious, always looking for ways to identify quality in an amp or lack of.
Power Supply Questions dezzz Chip Amps 3 13th August 2007 08:43 PM
questions about power supply for 6l6 pp dionisio Tubes / Valves 18 10th March 2005 02:14 PM
12-14V power supply questions. DJNUBZ Solid State 2 10th January 2005 11:37 PM
p68 power supply questions kinser Solid State 15 11th October 2004 10:38 PM
Power Supply Questions wrl Parts 7 29th December 2003 05:06 AM
Page generated in 0.08418 seconds (73.07% PHP - 26.93% MySQL) with 10 queries
