when i got this amp the two big brown resistors were unsoldered from the board...i put them back in. powered the amp up ,and now they get so hot they will unsolder from the board again.....???
ive tested all the small transistors around the brown resistors, and the gate drive transistors they have 2 readings of 0.6.... i dont have any shorted power supply transistors or outputs, or a shorted torrids... ive never seen resistors get so hot it falls out of the board by itself...lol
#2 |
Are these resistors in series with Zener diodes (generally orange or silver)?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
there are 2 black with a silver stripe zeners that are hooked to them, plus the 4 zeners in between the torrid and the brown resistors...
#4 |
I don't think the diodes in the group of 4 diodes at the end of the resistors are Zeners. The ones connected to the resistors may be Zeners. Can you read the numbers on them?
#5 |
edit; the 2 glass diodes do not run to the big resistors...i had to cut away the glob of silacone to see where it went....
the part numbers of the 4 grouped diodes are.....all i can make out is FR54 ? FP54? should i fire it up and get some readings from the 949? |
#6 |
The large resistors are commonly used in regulators. They go between the rail supply and a zener diode. The other end of the zener diode goes to the secondary ground. Is that what you have?
#7 |
im not sure perry.
there is a single wire coming off the torrid that is running to one of the big resistors... the group of 4 diodes are running i between the rail and the big resistors, which are connected to the secondary ground .... the secondary ground is the black wire that mounts to the heatsink right?. |
#8 |
I'm not familiar with the amp so I can't help much more without more information.
The secondary ground is generally tied to the non-bridging speaker terminals. If the Zeners were connected to the secondary ground, they should be connected to the non-bridging speaker terminals. If you find that there is 0 ohms between the non-bridging speaker terminals and the Zeners, then they may be the Zeners being used for voltage regulation (±15v). The Zeners for the ±15v will have ~15v across them.
| First gen 250 Orion | SS64 | Car Audio | 8 | 6th January 2009 01:10 AM |
| First Gen 225 Orion | SS64 | Car Audio | 13 | 14th December 2008 11:54 PM |
| Orion 250 amp | mike49504 | Car Audio | 11 | 21st November 2008 04:45 AM |
| Orion NT 200 vs Orion 2150 SX | Clipped | Car Audio | 3 | 12th June 2007 01:55 PM |
| Need Help With Orion 600 Amp!!!! | Shades710 | Car Audio | 1 | 20th July 2004 09:04 AM |
| Page generated in 0.07791 seconds (83.46% PHP - 16.54% MySQL) with 10 queries |
