Has anyone designed a car amplifier that runs from the high voltage system of a hybrid car? I'm thinking designing the power supply for it would be almost exactly like designing a power supply for a home amp. In fact, many engineers have run unmodified universal input power supplies from the high voltage system of a Prius, meaning an off-the-shelf power supply can be used!
The obvious benefits would be greater power available (great for those building loud car stereos!) as well as higher efficiency due to lower currents needed. The obvious downside is that more care would be needed when connecting the amp, but it really isn't any different from wiring home AC power.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#2 |
what's the voltage does the hybrid car runs on? 24V? 48V?
#3 |
every car has its own setup, seen 100v+ cars too. there you would need only full bridge D amp[output stage] and you would have several kw
But I wouldn't do that, batterys are not that good to have so many large consumers to power |
#4 | ||
http://priups.com/riddle/answer-1.htm And universal input power supplies will run from the electrical system of a Prius: http://priups.com/misc/bonus-large.htm
#5 |
How about an Amplifier that runs off of petrol?
Fuzzymuff
Wrap it in foil, and plug it in. |
#6 |
I tested the amp on that alpine pl7 or whatever its called box with that tymphany LAT driver in it. It has +75v rail only and does 500rms it says, class D. The output section is a bang & olufson. I wonder if it is an icepower amp, I don't know.
#7 |
dont think its a wise idea to tap off the main battery pack. bass transients might actually trick the car into thinking the batteries are lower than they actually are and cause the engine to sit there and start/stop trying to recharge.
id go with a class D amp or tripath based amp that has little draw and connect to the small 12v battery.
certified packrat |
#8 |
That is not that true, you can have taken samples of battry voltage, and if say 10 samples over 10s say the same, then you could say battery is empty, I don't think it would be a problem in this case
#9 |
My Electric Car is equipped with a DC to DC Converter that has an input range of 120 – 350 VDC (http://www.powerconversion.com/assets/mp_1227738018.pdf), the output is over 40 A at 14 V.
| The Hybrid Class A amplifier | gaborbela | Tubes / Valves | 135 | 24th May 2012 05:33 PM |
| The Perfect Hybrid Amplifier | Stee | Solid State | 0 | 27th July 2008 08:03 PM |
| Hybrid amplifier A2 class | Jaime | Tubes / Valves | 8 | 11th July 2007 01:28 PM |
| Hybrid amplifier.. Please help.. | DoomPixie | Solid State | 96 | 2nd March 2006 02:54 PM |
| Hybrid amplifier help... | DoomPixie | Tubes / Valves | 83 | 20th February 2006 01:28 PM |
| Page generated in 0.09683 seconds (85.67% PHP - 14.33% MySQL) with 10 queries |
