Go Back   Home > Forums > General Interest > Car Audio
Old 3rd April 2009, 05:44 AM   #11
That amp appears to be a chip-amp. If that's true, there are no non-bridging speaker terminals so the last test I suggested won't work with this amp.
Old 3rd April 2009, 09:26 PM   #12
Crap.
Thanks for your help. I guess it's just not meant to be...
Old 7th April 2009, 12:27 PM   #13
Dan2 is offline Dan2  South Africa
my pioneer head unit also gave me engine noise through the amp. even though i measured a short between the RCA shield and head unit chassis (when the RCA's were connected), i soldered a wire to one of the RCA shields (behind the head unit) and as soon as i touched it to the frontloader chassis the engine noise went away!
Old 1st May 2009, 07:57 PM   #14
I got two words for you... Ground Loop. Well for starters the amp should have its own power and ground points. I would suggest running an external power wire to the amp then test the system. If the problem persists then its a for sure ground loop. Reground the amp while still using the external power supply. Retest the system and the whine should be gone. Make sure when you reground the amp, the grounding point is free of all paint and dirt. Try to reground at a point where the contact being made will be a solid connection to the chassis.
If you follow the steps I have just given you and the problem still persists then repost or IM me. This is a fairly common problem and can be solved fairly easy.
The level of performance in any mobile sound system is a direct result of the way it was installed. Passion, pride, perfection.
J. Kim~I.A.S.T.
Advice about modifiying speakers needed stubs Multi-Way 7 13th September 2006 03:21 PM
Advice needed for new speakers! Timbo Multi-Way 12 2nd September 2006 10:54 AM
Basic Grounding/Engine Whine Dfere Car Audio 3 8th May 2004 06:07 AM
Engine whine feelinhipp Car Audio 3 13th March 2004 05:53 AM
My 1st car amplifier!..engine whine problem. deepanger Car Audio 19 20th October 2003 12:09 PM
Page generated in 0.08545 seconds (70.76% PHP - 29.24% MySQL) with 10 queries
