I have a PPI A600 that is being upgraded. New caps, new op-amp and few more tweaks in the pre section.
I have been told that replacing the 6 IRFZ44 with 4 IFR3205 will have positive impact on the sound quality. Is this true? Why? Thanks |
#2 |
Changing the power supply FETs isn't likely to have any audible effect. The Z44s can do everything the amp needs them to do. The original transistors were likely 25 amp FETs (RFP25N05s?). The Z44s are 50 amp FETs.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Thanks Perry.
My 600.2 has the 44 when I purchased it. So, reducing the number of transistors from 6 to 4 has no real benefit to some parameters like distortion? In this case, money saved |
#4 |
Until you drive the amp to clipping, there won't be any audible distortion.
The A600s that I've seen all had 8 power supply FETs. Does yours have only 6? Did someone tell you to use less than the original number of FETs?
#5 |
Sorry - I mixed up the numbers
It's a 600.2 and has 5 per side And I was told to use 4 per side (totalling 8 instead of 10) |
#6 |
If there is a place for 10, use 10.
#7 |
ok - got it
#8 |
10 to220's = better heat dissipation than 8 =
Don't worry... you can always turn the gain down! |
| PPi A600 noise | MHFidelity | Car Audio | 5 | 29th September 2008 06:13 AM |
| Ppi A600 | npenson | Car Audio | 4 | 27th August 2008 10:36 PM |
| profile A600 2 ch | jrod666999 | Car Audio | 9 | 18th March 2008 10:26 PM |
| Help with a damaged PPI A600.2 | punchpeanut | Car Audio | 7 | 16th February 2004 05:30 PM |
| Page generated in 0.07827 seconds (74.49% PHP - 25.51% MySQL) with 10 queries |
