Go Back   Home > Forums > General Interest > Car Audio
Old 1st April 2009, 11:16 AM   #1
NED 209 is offline NED 209  Ireland
NED 209's Avatar
Default loudest subs.
hi all. i currently have twin 12" subs in a manufacturers proper ported box, and its very loud. however, i want more.
im contemplating twin 15"s, im a box, for instance i like to look of some of the vibe models. twin 15s are of couse, bloody huge, and my next car will be pretty small. but i dont mind. ill just take out the rear seats and put the subs in instead.
i quite like the look also of the poineer ts wx206e
http://www.pioneer.co.uk/uk/products...06A/index.html
because its pretty darn small, but promises a lot of bass, or, on the flipside of that, one of these bandpass monsters, that i wont pretend to understand -
http://www.raysmith.co.uk/AC-S15-Twin/
"if it looks right, it probably is right..." well something that ugly should make a serious racket....
has anyone heard any of the active pioneer subs? i lke pioneer their stuff is quality, always pleases me. basically though how should i get the deepest most powerful bass possible in a car?
please and thanks,
ned .
Old 2nd April 2009, 05:40 AM   #2
dangus is offline dangus  Canada
It comes down to drivers squeezing air, so you want many cones and as much excursion per cone as possible. Efficiency is sort of moot, since less efficient drivers can work in smaller boxes, so you can run more of them. And more drivers increases efficiency and power handling. I suggest using a clear plastic baffle behind the front seats, with as many 15" as you can fit. That'll reduce cabin volume which should provide a useful boost in gain.
Old 2nd April 2009, 07:58 AM   #3
NED 209's Avatar
thats a pretty sick idea.
what about correct enclosure volume etc.?
PRETTYMUCH SARRIFICES ALL THE SPACE IN THE BACK THO. I WAS THINKING MAYBE caps lock sorry was thinking mabe two of those pioneer wx 206a subwoofers would provide lots of bass in a small package
if i was to go the 15's route what kind of woofer am i looking for? thinking of about 2000watt amp, hmm dunno what that is rms.
i have an alpine 4 channel that i going to drive 4 infinity 6x9s with, then another amp for the subs
Old 2nd April 2009, 06:44 PM   #4
Loudest subs......the list goes on and on, here are some you could push w/2k.
http://www.woofersetc.com/p4912/SE15...-Subwoofer.htm
http://www.woofersetc.com/p2691/D915...-Subwoofer.htm
http://www.woofersetc.com/p2533/SWR1...-Subwoofer.htm
http://www.woofersetc.com/p2160/P30-...-Subwoofer.htm
These are all relatively affordable suggestions seeing as you'd like to run a pair. Also, I'm happy to help, but you need to understand that asking "Whats the loudest sub", has many more variables that come into play than just the driver. Box config, tuning frequency, cone area, cabin gain, etc. all will determine the end result.
It is only rarely that one can see in a little boy the promise of a man, but one can almost always see in a little girl the threat of a woman. ~Alexandre Dumas
Old 3rd April 2009, 10:02 AM   #5
NED 209's Avatar
hey there Steviedon, i like your sig. very good.
i like the Alpines. plus theyre second hand on the bay for not-a-lot. i understand the rudiments of box design... i built a sealed box for a sub before and it turned out pretty good.
tuning frequency. well i want to listen to dubstep and very bass heavy electronica with the subs. ive got the impression that ported would be the way to go for what i want. cabin volume - that im unsure of at the moment. im in New Zealand about to return home to Ireland, and since car sound is my latest obsession im planning early, but not 100% on which car yet.
itll be either a small car like a fiesta, or if i can swing it, a large van. not much to go on there then..
Convert floor standers to subs with Tang Band 8" subs? prerunnerv6 Subwoofers 3 26th February 2006 12:44 AM
2 subs one box/2 subs 2 boxes vetkilr Subwoofers 5 22nd February 2006 09:27 PM
loudest enclosure type? MEXXX Multi-Way 17 20th October 2004 12:05 PM
Loudest quality Mid-Tweeter combo. Recycle-Bin Car Audio 4 24th May 2004 03:46 PM
advice needed- lightest, loudest, lowest sub eRiCdWoNg Multi-Way 22 25th February 2004 12:47 PM
Page generated in 0.09050 seconds (75.54% PHP - 24.46% MySQL) with 10 queries
