i have a visionik 900hc that has a blown power supply, but the question i have is.
what can i use to replace the sanken c-3856/a-1492's that are in the output section..?? 16 on each side of the amp.... the amp had only one output that was shorted out in the whole output section.... i plan on replacing the power supply with the original irfz44n's , but if you think the irf3205 would work, i could use them..... |
#2 |
The original outputs are readily available.
In an amp this large, you should use the original parts. If there is some incompatibility (may not be immediately obvious), you could destroy a lot of parts.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
| do i REALLY need a crossover?? and an amp question. and an ohm question | legendaryfrog | Multi-Way | 4 | 29th October 2006 01:39 AM |
| newbie with input tran. question and wiring question | imo | Solid State | 0 | 18th January 2006 10:10 PM |
| PS question - tformer question actually | breguetphile | Chip Amps | 2 | 30th May 2003 01:29 PM |
| old speaker question, bullet midrange question & link to speaker project | wallijonn | Multi-Way | 10 | 5th November 2002 06:03 AM |
| Page generated in 0.06894 seconds (70.03% PHP - 29.97% MySQL) with 10 queries |
