Go Back   Home > Forums > General Interest > Car Audio
Old 31st March 2009, 12:35 AM   #1
Default ppi pc2150 distorted right channel
just replaced power supply fets and output transistors in a pc2150. hooked it up and left channel has full power but the right channel is week and kind of distorted sounding. what could be the problem?
thanks
Old 31st March 2009, 05:59 AM   #2
Did you check the big resistors tied to the outputs, they like to open up.
after those I would look at the SIP driver card, among other possibilities these come to mind as most prevalent failure wise.
Look for melted or missing components on the ceramic cards...and possibly you might have to carefully reflow all the solders on the SIP card < this works very often to restore the proper operation> Careful though, it does not like solder flux and excessive heat on those SMD solder connections, you can destroy the card if you not careful
And these cards must be hand made to replace, PPI does not support these anymore, and unless you strip another amp you must build replacements ...At least that's what Perry and I do when we need these....
Old 31st March 2009, 09:40 PM   #3
ok i will check the resistors first. if those are all ok i will look at the cards, i think the one on the right is discolored where it attaches to the main board, it is dark brown like it may have been overheated. if i do need to rebuild the board, are the parts easy to find? thanks for your help
Old 2nd April 2009, 02:49 AM   #4
i checked the resistors and they are all ok. the small board is screwed up. the legs on the bottom were loose and not connected to it anymore and a couple surface mount transistors were also not connected.. i could not resolder anything, i cant figure out how you do it. but i did solder some jumper wires to the components and the right channel now works fine. i would like to fix it the right way could you tell me the secret on how to solder these thing back to the porcelin board? thanks
Old 2nd April 2009, 03:10 AM   #5
The solder pads on some of these boards are not solderable. When you apply heat (nothing else) the solder will draw up taking the pads with it. Other boards are readily solderable and have no problem with pads lifting.
Sometimes, you can scrape the mask off of the trace and make the connection with a small strand of wire.
Can you post a photo of the board?
Old 2nd April 2009, 03:36 AM   #6
If you see brown colored surfaces where the solder needs to be, your SOL on resoldering those contacts. The surfaces are destroyed and un-solderable under any conditions I have ever seen.
Believe me I have tried in the past, and its a no go situation. Not even flux will make solder adhere to that brown surface.
If, you still have solder left at the contact site, then you must use a tad bit more heat, and some good fine electronics solder. Don't get carried away and over heat whats left as it is easy to finish off the connection this way.
The ceramic SIP card has unique thermal characteristics hence the reason I think it was used for this device. All the devices mounted on these SIP's thermal track one another and this limits DC offset issues due to temperature variations...IMO
Perry and I both build our own replacements on a as need be basis, because Directed / PPI has left all there loyal old school customers hanging on these cards.
Old 3rd April 2009, 10:40 PM   #7
jol50 is offline jol50  United States
I had some glue, it was in tape form. You heat it to I forget but 350F or something and it will glue metal together and when it cools I think it will not melt again. Is very thin, I think you could glue copper onto ceramic but it would be a matter of being able to physically do it. I can find a datasheet on it maybe if you think it would be of use. I can get a piece of it. May be this stuff: http://multimedia.3m.com/mws/mediawe...6EVs6E666666--
You could put it on the copper then hold it on and iron it more or less. It turns dark when cured. Just an idea. It is only 10 mills thick so it does not slop around. We would clamp it together in an oven.
Old 7th April 2009, 12:15 AM   #8
i will post a pic of the board asap, i got the channel to work by running small jumper wires to the components. im not sure how long it will last though. thanks for all the help.
Old 28th August 2009, 01:12 AM   #9
TO-3 is offline TO-3  Peru
TO-3's Avatar
Send a message via Yahoo to TO-3
How do you really feel? Have a beer.
Check out Tube Driver BLUE products at: www.tubedriver.com
Old 28th August 2009, 01:23 AM   #10
Send a message via AIM to DigitalJunkie
Humm,This reminds me of those ceramic terminal strips used in old Tektronix equipment - they required silver solder,regular solder would 'contaminate' the plating,and dissolve it.
Perhaps those cards are similar?
Distorted left channel - Marantz 2385 jblmar Solid State 2 27th March 2009 05:04 PM
Pc2150 SS64 Car Audio 4 14th March 2009 03:58 AM
Distorted left channel Proton 520 Amp allank Solid State 1 13th September 2006 01:41 PM
put my pre-amp together and now the left channel is playing distorted :( elizard Solid State 21 4th April 2003 06:23 AM
Help!! Right Channel Freq distorted. TPC Tubes / Valves 3 16th January 2003 02:27 PM
Page generated in 0.10871 seconds (78.86% PHP - 21.14% MySQL) with 10 queries
