Rockford Fosgate P800.2 [Repair]
Old 19th May 2010, 09:45 PM   #91
Brain Fried is offline Brain Fried  United States
Brain Fried's Avatar
Originally Posted by carlogics View Post
After reading, I am really amazed at how people stabbing each other in this ...
I sit with a problem but with the Rockford Fosgate power series 800.2. the model more ...
The problem is ... the amplifier is receiving power and consumes power (I can see the voltage of the capacitor) ... He makes no error code or protection ...
it does not send sound through to the subs ... I already have some lying around and ask it would be the final stage .... or as the previous one at the transistors ..
is this correct?? can anyone help me with schematics and wiring diagram of the Power 800.2?? any information is welcome ...
greetings to anyone who can help me ...
Yours sincerely
Go Here > http://194.204.29.93/rockford/techli..._schematic.pdf
Old 28th May 2010, 09:34 PM   #92
carlogics is offline carlogics
Originally Posted by Brain Fried View Post
beste bedankt al voor deze informatie..
ik heb nog een vraagje... alle getallen en nummers na de eindtrap of transistor zijn die van groot belang voor te bestellen?
b.v. IRF 9640 ... ...
want ik vind niet direct waar ik alles kan bestellen...
ook zou de sturing van de voeding stuk zijn... enig idee wat dit kan zijn of waar ik dit kan bestellen ? of onderdeel nummer?
groeten christof
Old 28th May 2010, 09:42 PM   #93
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
groeten,
This is an English speaking forum. If you wish to post in another language, post the translation also.
Thank you.
planet10 needs your help:
Let's help Ruth and Dave
Old 28th May 2010, 09:55 PM   #94
Originally Posted by Cal Weldon View Post
groeten,
Thank you.
best thanks all for this information ..
I have a question ... all numbers and numbers after the amplifier or transistor are important to order?
e.g. IRF 9640 ... ...
because I think everything that I could not directly order ...
also, the control of the food piece are ... any idea what this could be or where I can order? or part number?
Regards Christof
Old 29th May 2010, 04:30 AM   #95
Regards Christof
Dutch
voor de energie voorziening, u kunt de IRF3205 gebruiken, maar u moet de gate wijzigen van 47 Ohm weerstanden 51 ohm.
for the power supply, you can use the IRF3205, but you must change the gate from 47 Ohm resistors 51 ohm.
Old 7th November 2014, 02:05 PM   #96
olds442 is offline olds442
I have this amp an it doesn't turn on an im clueless on it any suggestions where to star adamhawkins74@gmail.com any help would b great
Old 7th November 2014, 04:58 PM   #97
Perry Babin is offline Perry Babin  United States
Please don't post in a repair thread that was started by someone else unless you are trying to help them.
Click on the red triangle in the lower left corner of your post and ask a moderator to move your post (and any replies to it) to a new thread (my post should be deleted).
Old 7th November 2014, 06:47 PM   #98
I am new to all this I seen post on google an signed up for this site im only tryin to get help fixing my amp guess I will read more into this site
Old 7th November 2014, 09:12 PM   #99
The moderators don't bite. If nothing else, ask them to delete these posts and start a new thread.
Rockford Fosgate P800.2 [Repair]Hide this!Advertise here!
rockford fosgate punch z stevena2006 Car Audio 2 23rd December 2009 04:20 PM
Repair of Rockford Fosgate Punch 201s Jackson75 Car Audio 15 3rd November 2009 10:34 PM
Rockford Fosgate 325.1 phreaktor Swap Meet 1 28th February 2008 11:54 PM
rockford fosgate transistors mike49504 Car Audio 2 20th January 2007 03:26 AM
New Rockford Fosgate amp. $50.00 NerdMike Swap Meet 0 4th March 2005 11:57 PM
