Go Back   Home > Forums > General Interest > Car Audio
Old 26th March 2009, 12:20 AM   #1
Default us acoustics usx1000 (zed) problems
i have a small problem, or maybe a big one. my us acoustics started to smell as if it were fried, but it never shut off or lost power. infact it still worked great. but when i took it apart to see what was going on i found that one of the power supply fets was broke off the board!! and the one across from it on the board was dead. i had a bunch of irfz44 transistors laying around and thats what was in the amp so i replaced the two bad ones and put it back together. after cranking it up a few times i noticed the smell again. so i took it back out and checked the power supply transistors again. they were all ok!! so now i find that one of the big output transistors has one broken leg and the one across from it is loose in the board. i pulled both out and a few others and checked them all and they all are ok. so i put it all back together and made sure the board is secure in the heatsink. but i have not yet hooked it up. im just wondering what could be causing that smell. there is no sign of burned up parts and no burned traces. so could it have been the loose or broken output tranistors?, even though they arent bad?
fm acoustics ben goh Solid State 28 8th April 2012 09:24 AM
Q's about the acoustics of fans nunayafb Everything Else 0 29th March 2006 04:19 AM
Raw Acoustics HT3 audioferret Multi-Way 15 12th March 2006 12:48 AM
Need help in Acoustics! audioPT Multi-Way 13 1st December 2003 10:13 PM
Page generated in 0.06630 seconds (64.66% PHP - 35.34% MySQL) with 10 queries
