Im working on a kicker 600.1. The amp powers up and idle's fine.
But the is no output from the amp just a high pich squeal. Wondering whatshould i check first Any help would greatly be appericated |
#2 |
If you twist the output filter inductor, does the noise change?
Do you have a 80-100k triangle waveform on pin 4 of the defaced IC that's NOT near the blue crystal?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
unless i did it wrong i dont have a nice triangle wave form on pin 4 wondering where i go from here
#4 |
If I'm not mistaken, kicker always uses pin 4 for the triangle waveform input. Confirm that it's not on pin3 either (in case this amp is different). This IC is an LM361.
If it's not on 3 either, confirm that you have a square wave signal on most of the pins of the defaced IC (mc14060) near the blue crystal. This IC should have 12v on pin 16 and pin 8 should be at ground (secondary ground). Also confirm that you have ±12v on pins 1 and 7 of the LM361.
| Kicker L5 in a 1.75 box | skooter | Car Audio | 4 | 16th October 2008 01:54 AM |
| Kicker L7 | skooter | Car Audio | 5 | 25th September 2008 11:36 PM |
| Kicker 500 si | stormtrooper | Car Audio | 0 | 25th September 2006 01:20 AM |
| adire? kicker? anybody? | jadenlinkletter | Car Audio | 5 | 22nd April 2005 01:37 PM |
| Kicker: KX vs. SX | NaftaliG | Car Audio | 0 | 11th December 2004 08:21 PM |
| Page generated in 0.07633 seconds (69.19% PHP - 30.81% MySQL) with 10 queries |
