MTX 280, no output
MTX 280, no output
Old 20th March 2009, 04:21 PM   #1
ECM is offline ECM  United States
Default MTX 280, no output
Working on an MTX Thunder 280 with no output.
Power supply is good with +/-25 volts.
Power to opamps is good with +/- 18 volts.
Outputs are not shorted, amp turns on and stays on just fine. No overheating and no signs of overheating.
Opamps appear to be fine. I bypassed the opamps by injecting an audio signal to pins 1 and 7, the opamp outputs (ne5532), with no change in amplifier output.
No change with the crossover engaged or off. EQ and Gain pots measure identical and turning them does nothing.
The only thing I have to go on now is this. When I play music thru the amp, I will hear output for a split second, then off again, over and over. Muting or protection circuit maybe?
Any ideas?
ECM
Old 20th March 2009, 07:03 PM   #2
Perry Babin is offline Perry Babin  United States
The LM339 controls the output. When you have audio, do you have 0v on pin 13?
Old 20th March 2009, 09:37 PM   #3
I'll check the LM339 Mr. Babin. The amp is at work, I'll be in on Monday.
Old 20th March 2009, 09:51 PM   #4
Since you don't have easy access to it, post the voltage on all of the pins of the 339.
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Old 23rd March 2009, 12:06 PM   #5
Hooked the amp up this morning and it will not turn on!
I measured the voltage on the pins anyway:
1- 0.6
2- 5
3- 30.5 <--I have no idea why it's reading 30V. Checked it twice
4- .389
5- 3.2
6- .226
7- 3.2
8- 3.7
9- 5.03
10- 5.3
11- 7
12- 0
13- 0.6
14- 0.6
Old 23rd March 2009, 12:25 PM   #6
What is the supply voltage on the B+ terminal? The supply voltage on this pin is typically the B+ input minus -.6v (drop across diode).
Old 23rd March 2009, 12:44 PM   #7
The input voltage is ~12 volts. I've had this issue before with my power supply and MTX. For some odd reason the amp affects the regulator in the power supply. I'm ordering a switching power supply off ebay today.
The amp in my other post, an identical MTX, turns on just fine.
Old 23rd March 2009, 01:03 PM   #8
This comparator may have a shorted channel. According to the inputs, all of non-inverting inputs are higher than the inverting inputs so all outputs should be high. Is there an external component tied to pins 1, 13 or 14 that's pulling the voltage on that circuit down?
It may also have an open connection to the pull-up resistor(s). Pins 1, 13 and 14 probably go to a resistor and then to the base of a PNP transistor. There is likely another resistor between the base and emitter (which is tied to the 5v reg). These two resistors should be pulling those 3 pins up.
Old 23rd March 2009, 01:35 PM   #9
Pins 1,13, and 14 are tied together. There are no open lines or shorts between those pins and the resistors leading to the PNP MPSA56 transistor.
In circuit, the transistors all measure good. No shorts or opens and all are identical.
I'll get a few LM339's on order and see if that's the issue.
ECM
Old 24th March 2009, 12:20 PM   #10
Installed new LM339, no dice.
Pin 3 still reading around 30V. I have a multimeter directly connected to the power supply and it's at 12V. Bad input power supply cap maybe?
MTX 280, no outputHide this!Advertise here!
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output iklari14 Digital Source 30 18th July 2003 12:57 PM
