Battery Load with New Amp
Old 21st March 2009, 03:13 PM   #21
infinia is offline infinia  United States
infinia's Avatar
Originally posted by caraudio
So we're back to the amp. Is this brand new amp a defective amp, and just by coincidence it does the EXACT same thing as my old amp??!!?
Unlikley
Sounds like the amps "remote turn on input" never goes off.
Measure that input to the amps (-) terminal
Then again to to batt (-) terminal
If you have extra batteries or BFC'stemporarily remove those trouble shoot.
edit>Not sure if this is you but, Using Chassis for multiple power gounds is trouble waiting.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 21st March 2009, 03:31 PM   #22
caraudio is offline caraudio  United States
infinia. Thanks for the input!
I'm sort of a novice with electrical circuits. How would I go about doing that...which probe where? And are you talking about the negative terminal of the car battery?
If you have extra batterieries or BFC's temporalily remove those trouble shoot.
I'm not sure what a BFC is. But the only thing hooked up to the amp is the B+ and the ground. There is only 1 battery in my car, and there are no batteries in my amp.
Not sure if this is you but>Using Chassis for multiple power gnd is trouble waiting.
The ground originally for my car was a small hole drilled in the frame of my car and I grounded it that way. It worked for many, many years. When I went under my hood I screwed the ground into a bolt which connected to the frame. Is this not a good ground?
I have never used this new amp. How would the "remote turn on input" ever be on in the first place?
Thanks so much, guys. I appreciate the input!
Old 21st March 2009, 03:54 PM   #23
infinia's Avatar
Use DMM on volts DC
2 measurements +meter to "remote on" at amp
1) - meter to amp power neg.
2) - meter to car batt neg.
BFC = Big F***ing Cap
Can connect remote on to amp power - neg. s/b off
Always ran double wires to amps myself. Never really trusted chassis ground over long term because of corrosive elements and loose nuts/bolts. Can be done well tho, if careful.
Old 21st March 2009, 06:14 PM   #24
Perry Babin is offline Perry Babin  United States
That meter only goes to 250 milliamps. I don't know what settings you were using but it won't read 2 amps of current.
Are these MTX amps?
Old 21st March 2009, 09:39 PM   #25
Are these MTX amps?
Hmm. Well I feel dumb. When it said Amps, I didn't know it was MilliAmps. So all along when I thought I was drawing 2 amps, it was really 2 milliamps.
So here's the thing. This is exactly what my old amp was drawing too, which was draining my battery after a day or two of being parked. I guess this is why I supposed it was full amps instead of milliamps (as well as my vast gap of electrical knowledge). So I just wonder what the real problem was with my old amp? Perry, the new amp is a Phoenix Gold V752 250 watt.
I guess I need to double check my remote. What's the best way, with the meter I currently have, to test to functionality of my remote?
Hey, guys, I really really appreciate your help.
Old 21st March 2009, 09:46 PM   #26
Set the meter to the 50v DC range. With the black probe on chassis ground and the red probe on the remote turn-on, you should read ~12v when the head unit is on and 0v when it's off.
Old 22nd March 2009, 12:12 AM   #27
ppia600 is offline ppia600  United States
Two milliamps would take a LONG time to drain your battery. That totally wouldn't be the problem. What vehicle do you have? I've had a few customers come in griping their amps or radios were draining their batteries and it would usually be a trunk or dome light staying on, a few times it turned out to be defective alternators dissipating power internally. If you don't have any lights that stay on, feel the alternator with the engine cold and see if its warm. (Of course you'll need a charged battery that's been connected to the car for a few hours.
Try this:
-totally disconnect ground and power at the amp
-disconnect the car battery's ground and leave the + connected
-put your meter between the battery - and the - power cable and check for current draw
Regardless, if its only 2 milliamps that won't be the problem. Now, 200 milliamps could do it, but it would still take over a day.
Don't worry... you can always turn the gain down!
Old 22nd March 2009, 03:34 PM   #28
Thank a ton, guys. I have it working now. And I've verified that it doesn't draw excessive amps all while the remote is working. I don't know what happened to my other amp, but this one is good to go now. I can't thank you enough!!
Battery Load with New AmpHide this!Advertise here!
Power load, dummy load (pic) luka Power Supplies 43 9th February 2012 02:50 PM
Battery Charger for 15V Li-ION Battery Pack ??? Jan Dupont Parts 2 11th April 2009 02:18 PM
Dynamic load line analysis using music and speaker load Michael Koster Tubes / Valves 0 7th March 2008 08:47 PM
The best load of gc digi01 Chip Amps 1 5th April 2004 07:18 AM
Zen.4 in a 4 Ohm Load? Rino odorico Pass Labs 8 18th September 2002 02:04 PM
Copyright ©1999-2017 diyAudio
