I have just recently got an amp free its suppose to be a 1,000 watt amp but when I hook it up the protection like comes on then goes off like it should but the Power light has been broken and the amp is not putting out anything. I took it apart and never seen any burnt parts is there something specific I should be looking for ?
#2 |
When the red light goes off, can you hear the relay click?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Hey there! im new to this forum. Glad i found this very interesting activity's in here. anyways not to thread jack but im having the same issues with the same amp 1000.1 memphis amp. when the power is connected in like a few seconds the relay CLICK's! then it goes onto Protection mode. Open it up nothing is burnt? What could be the problem? any helps would be appreciated!
#4 |
Are you sure it's the same amp. I can't find any Memphis amp that uses the model number of 1000.1 that's similar to the 16-ST/MC1000D.
#5 |
sorry about that. i just double checked it and its the "Memphis Power Reference 1000.1" i believe we are talking about the same one
#6 |
#7 |
check your email Parry
#8 |
hey, I have a real mc1000d and I have that same issue, I replaced the 3205's and checked the resistors and still have no output. I wish I had access to a scope but I dont. Are there any problem areas on the mc and st1000d's I should look for?
#9 |
Start a new thread and post the DC voltage on all pins of the TLx94 IC on the power supply driver board. Place the black meter probe on the amplifier's ground terminal. Place the red meter probe on the point where you need to measure the voltage. Copy and paste the following list into your reply.
Pin 1: Pin 2: Pin 3: Pin 4: Pin 5: Pin 6: Pin 7: Pin 8: Pin 9: Pin 10: Pin 11: Pin 12: Pin 13: Pin 14: Pin 15: Pin 16:
#10 |
thanks perry, sorry for thread digging. I wish there were people like you in the automotive tuning field.
| Memphis...? | hooverjr10 | Subwoofers | 0 | 14th December 2007 03:16 AM |
| power supply issues memphise 1000d | jf8620 | Car Audio | 1 | 10th May 2006 10:05 PM |
| Memphis 1000D Transistor Blowing | jf8620 | Car Audio | 46 | 12th March 2006 10:49 PM |
| Kicker Vs. Memphis | irokpierce | Car Audio | 1 | 23rd August 2005 03:12 PM |
| memphis car amp | accept | Car Audio | 0 | 20th July 2003 05:36 PM |
| Page generated in 0.08128 seconds (86.62% PHP - 13.38% MySQL) with 10 queries |
