Go Back   Home > Forums > General Interest > Car Audio
Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 12th March 2009, 02:03 PM   #1
Default Precision Power PC6600.2 Amp turns on then immediately turns off. Need help!
Hi I got a used Precision Power PC6600.2 Amp that turns on then immediately turns off. I opened to check if there were any visible damages but I am unable to find any. Can anyone direct to what I should check first? Thanks in advance.
Old 12th March 2009, 08:57 PM   #2
Do not operate the amp without the cover in place.
Have you checked the output transistors to see if any are shorted?
The outputs are the ones with their 3rd legs connected to the large resistors. You should not read anything near 0 ohms between any of the legs of any individual transistor.
Old 13th March 2009, 12:42 AM   #3
How do I test it? I can't seem to find it. Sorry.
Old 13th March 2009, 01:20 AM   #4
I should have asked this before...
Did you confirm that the amp had sufficient voltage at the B+ and remote terminals and a good ground?
If the power supply feeding the amp is OK, read through the basic repair page below. It will make troubleshooting the amp much easier.
Old 15th March 2009, 02:12 AM   #5
Yes I currently have an amp installed, but it does not work when I use the PPI amp.
Thread Tools
On-off LED turns off when I turn the Power on! gychang Class D 4 6th July 2009 12:49 PM
Help with an amp, turns on but no sound HeavyD'sCustom Car Audio 40 5th May 2009 03:36 PM
Old school Coustic Amp 160:turns on with no remote power spooney Car Audio 17 16th August 2008 05:33 AM
Which turns you on? nl Digital Source 0 30th July 2004 10:50 PM
Page generated in 0.05944610 seconds (78.51% PHP - 21.49% MySQL) with 10 queries
Copyright ©1999-2010 diyAudio
