What's the simplest way to wire an amp?
Old 12th March 2009, 02:39 AM   #1
DeadSpeaker is offline DeadSpeaker  United States
Default What's the simplest way to wire an amp?
I drive a 92 mazda mpv that does not have a proper sound system. The radio doesn't play cds and the speakers are blown, so I'm going to replace the speakers. I don't need a fancy in dash cd player. I want to buy this amp, and plug a portable CD player into it. http://www.parts-express.com/pe/psho...number=265-079
Now I am a bit confused on how to power it. Doesn't the van's stock radio have ground and a +12 volt wires? I'd like to know if I could just disconnect the radio, and use those wires from the amp. And what should I connect the remote on off too?
Thanks a lot.
Old 12th March 2009, 02:51 AM   #2
HK26147 is offline HK26147  United States
Car electrical circuits use the metal chassis as ground.
The wiring harness provides various + taps fused to different ampere ratings.
Get a wiring kit from PE as well - at least something along this capacity
http://www.parts-express.com/pe/show...number=269-904
Old 12th March 2009, 03:08 AM   #3
Use this:
http://www.parts-express.com/pe/show...number=060-768
to switch another low current 12 V line for the remote on signal to the amp.
You can use the same red line ( 12v + ) that feeds the in dash radio; that way the line is always switched off with ignition.
Old 12th March 2009, 03:53 AM   #4
tsmith1315 is offline tsmith1315  United States
tsmith1315's Avatar
Default Re: What's the simplest way to wire an amp?
A couple of notes here. First, internal head unit amplifier problems often present themselves in a manner that would cause you to suspect a speaker problem instead. Before spending money on speakers, you may want to investigate further.
Next, the stock head unit may have a CD changer input jack on the back, which could be usabe to integrate the CD player while retaining the stock preamp controls. It was there on the cassette players, not sure about the CD units. If you're just looking to get the CD capability back, this could be an easy way. Alpine made an adapter to facilitate this in 1992, it was... I think 4901MA or 4902MA. I have an old Product Guide at the office and can look it up for you tomorrow if you're interested in exploring that route.
Lastly, you will truly get tired of fooling around with a portable CD while driving. Seriously, it gets old. It may be worthwhile to look for a cheap indash CD receiver, which would take the place of the factory head unit, amp and portable CD.
Tim
Old 12th March 2009, 10:21 PM   #5
Thanks for the feed back guys. I managed to remove the stock radio and found that it does have two heavy ground and +12v wires. I read that the +12 on the cigarette lighter is low current. Can I use this for the remote on off?
Old 14th March 2009, 12:50 PM   #6
weesatron is offline weesatron  New Zealand
yes you should be able to just check that it only has power when the key is in.
Old 19th March 2009, 12:38 AM   #7
I have that wiring kit now. For the main power, I am suppose to wire it directly to the battery. Why is this so? Could I get the main power from the inside fuse box?
Old 19th March 2009, 02:47 AM   #8
Because an outboard amp is a power hog and requires a substantial amount of current (amperage ) vs the typical device on a fused car wiring harness.
Give it a clean dedicated power line to the battery.
Old 19th March 2009, 04:03 AM   #9
Ah, I see. Thanks a lot.
What's the simplest way to wire an amp?Hide this!Advertise here!
simplest sub amp odysseybmx414 Solid State 2 28th December 2005 04:24 AM
The Simplest Pre-Amp MPW Solid State 76 5th November 2005 12:47 AM
Looking for the simplest DAC ever... martioz Digital Source 4 7th March 2003 03:09 PM
Simplest possible Mr. Triatic Solid State 7 17th October 2002 09:11 AM
Copyright ©1999-2017 diyAudio
