The other day I had been testing out a friends amp to test functionality. After I was done I was hooking my amp back up and forgot to disconnect the power from the battery while I was hooking it up. The power came loose from the amp and hit the ground which was already connected. The fuse between the amp and bat. blew, and I replaced it. Sense then the amp will not power on. No light, no safetymode, no fans, nothing. Here is a list of troubleshooting I have done so far.
-Tested all my cables (Remote, Changing the ground, power is hot, ect.) Hooked up a different amp and it powered on. - Checked fuses on actual amp, look fine and tested with a multimeter. - Used a multimeter and put the negative to the ground of the amp and possitive to the power (gave a reading) but when I move the possitive over to the remote I don't get a reading, but I am not sure if it is suppose to. - Disassembled the amp, and could not physically see anything out of place or fried. I'll post some pictures because I am new at this so who knows if you guys can see something I can't. Used the multimeter to test if the transistors had blown. They all gave me a reading but like I said, Im new at this and could only realy test to make sure none of them were open/blown. I'm not experienced enough to tell if the numbers mean anything. That is where I'm at. Im looking for ideas/ past experience/ advice... any kind of help at all. Thanks everyone, Cameron ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#2 |
Power up the amp and measure the DC voltage on all 16 pins of IC1. Place the black meter probe on the ground terminal of the amplifier. Copy and paste the list below when you post the voltages.
IC1 Pin 1: Pin 2: Pin 3: Pin 4: Pin 5: Pin 6: Pin 7: Pin 8: Pin 9: Pin 10: Pin 11: Pin 12: Pin 13: Pin 14: Pin 15: Pin 16:
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Im assuming th IC is the big black square in the middle? And what setting do I put my mulitmeter on to read the propper voltage?
#4 |
I think this should be IC1.
#5 |
After scrounging through the forum archives and using all sorts of keywords I found a post of guy who had the same amp and ended up havin the same problem. A tiny ground connection on the board had popped and needed soldered. You happened to be the same guy who helped him on that deal! Thanks for your help and Im sorry I couldnt find that post sooner.
| Help with Kenwood KA-94 | lumstar | Solid State | 0 | 7th January 2009 12:31 AM |
| kenwood kac-715 | purocolt | Car Audio | 5 | 4th September 2007 01:54 PM |
| Kenwood L-07D... | bulgin | Analogue Source | 0 | 14th July 2007 07:18 PM |
| Which dac has this Kenwood? | tubee | Digital Source | 5 | 22nd August 2006 07:34 PM |
| Kenwood KAC-628 car amp | wahee | Solid State | 0 | 21st September 2004 09:02 AM |
| Page generated in 0.09408 seconds (75.40% PHP - 24.60% MySQL) with 11 queries |
