Go Back   Home > Forums > General Interest > Car Audio
Old 26th March 2009, 04:08 AM   #11
Did the op-amps have positive AND negative voltage?
Did you reconnect the jumpers you cut to isolate the audio section?
Old 26th March 2009, 08:32 PM   #12
yes the ops had neg and pos voltage and yes i reconnected the jumpers for the audio side.
Old 26th March 2009, 09:11 PM   #13
Do you have positive/negative rail voltage on the center legs of the rectifiers?
Black probe on a non-bridging speaker terminal when measuring the voltage.
Old 26th March 2009, 09:58 PM   #14
ok some weird sh$t just happened when i tried that. at first i had nothing to the right one and when i touched the left one to the middle leg it made a big spark!! then all the sudden they work every thing that didnt have power now does. the right one has 19v and left has -19v. and i checked the outputs again and now they have 20v to the center leg also!!! dont know what just happened. the amp was making a real high pitch noise when it first powered up. then that big spark when i tried to check the rectifier, now no high pitch sound. tried to shut off amp and turn it back on to check everything again. and everything still works!!!??? but i still havent checked it for sound.
Old 26th March 2009, 10:04 PM   #15
The rectifier likely has a broken leg or a broken solder connection.
Old 28th March 2009, 07:03 PM   #16
SWEET!!!! this amp is working perfectly now. i fixed the connection on the rectifier and all is well. thanks again for all your help. just one more question about this thing. when bridging this amp do i use left pos. and right neg. or both positives? i see the previous owner had screws only in the positive terminals. i just want to make sure i bridge it correctly.
trevor
Old 29th March 2009, 12:50 AM   #17
You bridge it with the two terminals that do NOT have 0 ohm continuity between them.
Old Lanzar amp problem skooter Car Audio 3 10th January 2011 07:54 AM
fault with my lanzar 50c amp pulsarhks Car Audio 1 4th March 2009 03:40 AM
Lanzar car dvd player amphead123 Digital Source 0 22nd February 2008 07:08 PM
lanzar car stereo candlecutter Car Audio 4 10th January 2005 03:49 PM
Lanzar 600-S schematic Diode Car Audio 0 22nd March 2003 01:39 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
