Well I got them ordered and I made sure everything was correct.
I wont be able to install the parts until next week because I'm going out of town on Wednesday and I still need to get the aluminum bar. I called Menards and they only have about an 1/8 of an inch thick. I looked on granger and found 3/8 x 3/8 and I think ill just go with that.
The schematic doesn't have TC8, 18 or 20 so I don't know if you have them in the correct locations.
The center leg of the CTG rectifier should go to the positive terminal of the rail caps. The center leg of the CTRG rectifier should go to the negative leg of the rail capacitors.
- General Interest
- Car Audio
- help with 551s
