Go Back   Home > Forums > General Interest > Car Audio
Old 3rd March 2009, 08:26 PM   #1
fredrow is offline fredrow  United States
Default Need Help with Clarion Deck...PLEASE....
Hi I am working on a Clarion deck. DRX-9175.
Im just trying to find a Diode on Digi-Key to replace the Toshiba 1S1885A. If you know of another diode to use in place of this one please let me know. And Im also trying to find out what value the choke is in this deck. I will attach the schematics of it, any info is good. Choke (T401) on the schematic.
Email me and I will give you the schematic to look at.
MF_Fredrow@hotmail.com
Old 3rd March 2009, 08:48 PM   #2
http://www.bdent.com/search/part.jsp?partnum=1S1885
A 1N4002 is the equivalent.
The parts list should give the value of the inductor. If it's in series with the B+ line, it's not likely to be critical.
Old 3rd March 2009, 10:00 PM   #3
Yes it is in series with the B+, but they do not have a value for it. Only a part number which I believe it's just for the Clarion deck part number (009-0618-00)
Old 4th March 2009, 12:02 AM   #4
ahhhh, I think I was looking at this too hard. The choke is being used in a circuit for DC-DC converting. I believe they are using it to step up the voltage. Because if I'm not wrong, the voltage going to the deck is only 12.5V(from the car battery, and on the schematic right after the choke where it runs to the diode they have 13.9V writting on the schematic, so I can have to figure out what size of choke to use their.
What do you think??
Old 4th March 2009, 12:07 AM   #5
If they're using it as part of a power supply, it's critical to get the correct one. Have you tried pacparts to get the original part?
Don't believe everything in a service manual. There aren't many that don't have at least one mistake. If they were using this to step up the voltage, it would likely be more than a couple of volts. Can you post a screen cap of this area of the schematic?
Old 4th March 2009, 12:29 AM   #6
I sent you a copy of the whole schematic last night through your email.
Old 4th March 2009, 12:48 AM   #7
If you didnt get it just let me know......
Old 4th March 2009, 10:14 AM   #8
I didn't get it. The email will block anything over 20megs. Was it larger than that?
Old 4th March 2009, 02:37 PM   #9
It was way smaller, the file is only 8.6KB.....
Well I will send it to you again, Im off to School right now, so I will check for a message from you when I get home.
Old 4th March 2009, 03:16 PM   #10
That part isn't critical. For testing, you can bypass it.
Clarion HX-D10 problem 69CamaroSS396 Car Audio 5 29th October 2008 11:08 PM
Clarion c-bus and iPod MrRadi8 Car Audio 1 14th August 2007 01:04 AM
Clarion nbcd Car Audio 1 8th August 2005 05:27 PM
Clarion 1000hx 4 ch. amp wingman Car Audio 3 2nd February 2004 11:33 PM
Page generated in 0.09804 seconds (80.88% PHP - 19.12% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
