amp protection mode ?
That looks familiar. The largest transistors clamped to the sink, the pair on each side (top/bottom in photo), are the outputs. First thing you can do is see if any two of the three legs are shorted together for each one. If not do the same for the smaller ones near the transformer, upper right on the sink in the photo.
On the top and bottom of the photo, you can see two large transistors under the black clamps. Measure the resistance from leg 2 to leg 3 (see attached for numbering scheme). Do any read near 0 ohms?
Since you had one fail shorted from 1-2, you need to check the driver transistors. They will likely have their first leg directly connected to the first leg of the output transistors (the large ones clamped to the heatsink).
You'll have to remove them from the board to check them. If you're not sure how to check them, use the form on the following page.
http://www.bcae1.com/repairbasicsforbcae1/images/transistortestpage02.html
Post the screen caps of the readings you get for each of the 4 driver transistors.
There likely a resistor connected between the first leg of each of the outputs in each pair. You need to make sure it's not out of tolerance. With the outputs out of the board, measure the resistance between the solder pads for leg one of each output in each pair. It should be between 100 and 330 ohm. Do this for the top pair and the bottom pair of outputs. Is the resistance the same top and bottom?
