Alpine CDA-7995 Repair Q. Alpine CDA-7995 Repair Q. - diyAudio
Old 2nd March 2009, 06:57 PM   #1
ACraig is offline ACraig  Canada
Question Alpine CDA-7995 Repair Q.
Hello all, first post on here. From what I've seen, I'm not sure why I didn't find this place sooner
Now, onto the question...
I'm looking at picking up an Alpine CDA-7995 for pretty cheap, however it has stopped reading CDs, but everything else works fine...
I assume it's the laser pickup that's failed, it happened on my CDA-7949 once before, but after getting it repaired it's perfectly fine.
I'm pretty good with a soldering iron, and enjoy working on electronics, so my question is, what sort of difficulty level am I looking at for opening this baby up and replacing a laser pickup??
Further more, what would I need to get from PacParts to accomplish this task, just the Laser Pickup (81B50360Y01), or would there be other parts that would be worth while to replace while I had the top off?
Are there better parts places out there for Alpine parts?
ACraig
Old 3rd March 2009, 11:20 AM   #2
acid_k2 is offline acid_k2  Italy
are you sure your laser pickup is bad? laser lasts years, in normal use conditions...
Have you tried to clean the lens? have you checked rod and gears?
or maybe something else...
Old 3rd March 2009, 01:49 PM   #3
No one's replaced a laser pickup on an older Alpine deck before?
Old 3rd March 2009, 05:08 PM   #4
My 10-years old Alpine CD changer has no problem. Never replaced the laser. Very hard to break it.
Someone repaired your CDA-7949 once before? They have REPLACED laser head? Probably you have paid for that, but they have adjusted your unit, and laser head is probably still the same.
If you really want to change the laser head, order that, then open the unit, remove the mechanics block and replace the unit.
But if you want an advice, read this: http://www.repairfaq.org/REPAIR/F_cdfaq.html
Then try to open your unit.
Old 6th March 2009, 07:53 PM   #5
Anyone else have an opinion? :|
Old 6th March 2009, 09:08 PM   #6
Perry Babin is offline Perry Babin  United States
I'm not sure about Alpine decks but when replacing the pickup in Pioneer head units (years ago), the procedure was not simple. The procedure required that you put the head unit in a test mode and switch various circuits (focus servo, tracking servo...) on to make adjustments. Some of the adjustments were very sensitive. There was no way to get them right without going through the procedure in a specific order. I think Pioneer had more adjustments than others but it may not be as simple as replacing the laser pickup.
Old 14th May 2009, 01:57 PM   #7
Saturn V is offline Saturn V  United States
I also needed to replace the same part. (the orange ribbon was torn) Went over to Pac Parts and picked up the part.... Which is for Alpine CDE-7872.. I installed it and closely made sure to put it in exactly the way I took it apart......We'll to sat the least It still can't read the CD. I don't know why??? I even took it apart 2 more times and still gives me the code -----E Which means "Mechanism error" If anybody could help, I'd appreciate it. This is also my very first log in....
Alpine CDA-7995 Repair Q.Hide this!Advertise here!
Alpine MRV-1000 repair questions spooney Car Audio 40 28th July 2013 11:05 AM
Seeking input on repair of Alpine MRV-F400 amp Nagamitsu Car Audio 7 23rd April 2009 06:48 PM
Alpine cda 7995 no output amc32 Car Audio 10 16th April 2009 09:45 PM
Old School Alpine repair Nismoron Car Audio 9 21st December 2008 12:38 AM
Repair remote for Alpine PXA-H510 honfatboy Car Audio 2 19th July 2005 10:57 PM
Copyright ©1999-2017 diyAudio
