Go Back   Home > Forums > General Interest > Car Audio
Old 1st March 2009, 12:21 AM   #1
Default Heterodyne Alignment
Hi, I hope someone can give me a few pointers on aligning a '46-'48 Ford radio. This is my first time attempting this so I'm a novice. The aligning instructions for the radio state to attach the generator (B&K E-200D) high side to pin 6 (signal grid) of the converter tube low side to chassis. That is all good but to make the adjustments to the input and output IF's the radio has to be turned over. My question is this: How do I make the adjustments while at the same time holding the generator probe on the pin of #6 on the converter tube (on the other side) to get reception? Am I doing something wrong? It seems that there is an easy way, I just don't know how? I would be grateful for any pointers or suggestions. Thanks! Steve
Old 1st March 2009, 02:39 AM   #2
Would it be possible to solder a wire to pin 6 and attach the probe to the other end of the wire?
If it ain't broke Don't fix it
Old 1st March 2009, 03:16 AM   #3
I don't see why not. Have you tried this before? Is this the only way to do it or is there a more standard way? Thank you again!
Old 1st March 2009, 11:40 AM   #4
No. Not that I can think of. You are welcome.
Old 1st March 2009, 01:09 PM   #5
I'm going to give it a shot. I appreciate the suggestion!
DIY Time Alignment. clipto333 Car Audio 32 4th January 2011 05:48 AM
QB5 Alignment bigboy Multi-Way 1 19th September 2008 09:16 AM
Sig gen for FM alignment, diy? Conrad Hoffman Parts 10 15th December 2007 11:02 PM
Alignment Type teodorom Multi-Way 4 17th May 2004 11:21 AM
Page generated in 0.08672 seconds (68.98% PHP - 31.02% MySQL) with 10 queries
