Go Back   Home > Forums > General Interest > Car Audio
Old 28th February 2009, 11:43 PM   #1
SQLGuy is offline SQLGuy  United States
Default TIP 147's paralleled with no degeneration resistors?
Hi Folks,
I'm reparing a Coustic Power Logic 460. It uses pairs of TIP142's and TIP147's (TO-3P) for outputs. These pairs are completely in parallel (i.e. bases, collectors, and emitters all directly connected between the pair), but then share one 5W .1 Ohm resistor per pair on the way to the output (I guess to allow measurement of bias). The one I'm working on has one blown TIP147 - its "partner" is fine. I'm not surprised. My question is, did this setup ever work? How did Coustic expect paralleled Darlingtons to current share without emitter resistors?
Also, while I'm on the subject of design I find questionable... the temp feedback Vbe transitors are TO-92's effectively placed next to the heatsink and bent towards it a bit; there's nothing to hold them in contact. Did this ever work either?
Skeptically yours,
Paul
Old 1st March 2009, 03:00 AM   #2
jackinnj's Avatar
Time for a POOGE -- parallel Darlington's are a recipe for disastre (savez vous?)
Old 1st March 2009, 03:57 AM   #3
ppia600 is offline ppia600  United States
Default Re: TIP 147's paralleled with no degeneration resistors?
I never had any problems with my power logic 380 or 190 and they both had the same design. Cool amps IMO
Originally posted by SQLGuy
Hi Folks,
Skeptically yours,
Paul
Don't worry... you can always turn the gain down!
Old 1st March 2009, 05:08 AM   #4
I think I'm going to separate the emitter paths and replace the single .1 Ohm with a pair of .22 Ohms (one for each device).
Oui, je sais.
Old 3rd March 2009, 12:06 PM   #5
acid_k2 is offline acid_k2  Italy
Paul
some EEs are bad
and their design may be even worst...
Paul [/B]
the contact on the heatsink is optional; without that, the thermal feedback is a bit slower, and the bias current stays more stable on pre-fixed value.
Old 3rd March 2009, 04:01 PM   #6
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Car audio amplifiers wouldn't fail so often if they were well engineered...
Two darlingtons paralleled directly will never share current: The hottest one will exhibit lower Vbe and carry more current becoming hotter, the coolest one will exhibit higher Vbe and will carry even less current becoming cooler.
Don't worry too much about thermal feedback, most car audio amplifiers are plain class B (with crossover distortion) to avoid the cost of the bias adjustment process at the factory, and yours probably is class B too.
I use to feel like the small child in The Emperor's New Clothes tale
DAC 1955 paralleled fabiodord Digital Source 9 25th September 2008 10:20 PM
Optimal source degeneration resistance Nick Walker Solid State 5 7th July 2006 12:36 AM
paralleled rectifiers for +/-v ? snkby Parts 4 23rd May 2006 03:24 PM
DAC with paralleled TDA1541's sugano Digital Source 0 2nd May 2003 08:14 AM
Zen v4 with paralleled FETs Stanislav Pass Labs 15 4th March 2003 10:48 AM
Page generated in 0.10400 seconds (74.32% PHP - 25.68% MySQL) with 10 queries
