Go Back   Home > Forums > General Interest > Car Audio
Old 1st March 2009, 12:06 AM   #1
Default New member, amp overheating!
I have a 12" Pioneer sub (TSW305C) 800W max, and a MTX Thunder amp (TC2002) 200W, to run it. During the summer my amp is constantly shutting down from overheating. I'm not sure exactly how the amp is set up and was just wondering if there was some way of adjusting it (ie. bridged or not) to fix the problem.
Old 1st March 2009, 11:26 AM   #2
mikee55 is offline mikee55  United Kingdom
mikee55's Avatar
Default Hey there
More info is needed. Are you good at this or did you use a thin wire to power your amp? How good is your earth? Wiring is important, how is yours done. Tell us gauge/thickness, where did you connect your earth to, chassis?
Then, your driver could be wired wrong. Or a strand of wire splayed acroos a screw terminal.
More info, please.
Mikee55
Here will help http://www.bcae1.com/
If it don't work, I'll fix it in the mix! Or visit http://lsdp.proboards.com/index.cgi
Old 1st March 2009, 04:52 PM   #3
jol50 is offline jol50  United States
You can look it up on that site, seems like 8ga would be good for power wire and a secure ground to the car. Make sure you are not running it at a lower ohm load than the amp is for, I'd guess that amp is good for 4 ohms bridged and 2 not? Or if you are just running it hard and it gets hot eventually, you can remount the amp to a cooler place often the floor is coolest unless the exhaust is directly under it. What I do with some old amps I run that get hot, I put a relay on the remote wire and a PC fan blowing at the amp. You can run the fan right off the remote on older HU if you only run one amp, but newer HU handle less current so look that up or relay it. The slower fans are quiet and work well if fairly close to the amp say a foot or less. Those little fans take near no power. It is not good to overheat an amp all the time.
Amp overheating 3Dgeek Solid State 15 25th December 2005 04:20 AM
P68 Overheating!! led_zeppelin Solid State 36 7th February 2005 09:00 AM
overheating amp sndtch6 Solid State 1 21st April 2004 10:30 AM
overheating amp sndtch6 Car Audio 1 20th April 2004 10:00 AM
Page generated in 0.08204 seconds (70.93% PHP - 29.07% MySQL) with 10 queries
