amplifier power supply question
Old 13th March 2009, 05:02 AM   #21
Perry Babin is offline Perry Babin  United States
Is this wire (attached) in place and intact?
Old 13th March 2009, 05:16 AM   #22
ampjunkielikeme is offline ampjunkielikeme  United States
yes the wire is there , but the screw that is going thru the hole doesnt go into the heatsink..its a short screw
Old 13th March 2009, 05:34 AM   #23
Some of the kicker amps will do strange things if the heatsink isn't grounded. Find a screw that will go into the heatsink.
Old 13th March 2009, 06:26 AM   #24
that worked ....i was going to start pulling my hair out....lol
Old 8th April 2009, 06:09 PM   #25
dynosaur is offline dynosaur  United States
dynosaur's Avatar
Send a message via Yahoo to dynosaur
I am also working on a kx1200.1 , the 3205 fet's were all smoked as well as the drivers, i had seen that perry had suggested 47 ohms gates resistors instead of the 100 ohm as originals? Also just for my info , the original drive transistors in this one were labeled ASG D2 , however perry had said another part number? just wondering as to your reasoning for us who want to know.....
though i am gonna follow perry to his suggestions !!!
Old 8th April 2009, 06:40 PM   #26
When using the IRF3205s, I recommend using 47 ohm resistors if the original resistors had a value greater than 47 ohms.
I use the MMBTA56 as replacements for the KTA1504S (ASG) because they are rated to handle more current.
amplifier power supply questionHide this!Advertise here!
Car Amplifier Power Supply Perry Babin Car Audio 54 24th January 2014 03:58 PM
Fs : 13.8v/50a Delta Power Supply For Car Amplifier ANALOG GUY Swap Meet 0 19th November 2006 04:12 AM
Amplifier power supply question: K-amps Solid State 37 4th December 2003 12:47 PM
Capacitor Question - Amplifier/Power Supply thylantyr Solid State 6 18th April 2003 12:48 PM
Copyright ©1999-2017 diyAudio
