Go Back   Home > Forums > General Interest > Car Audio
Old 23rd February 2009, 09:29 PM   #1
Default crossover amp hookup
I have an orion amp I am trying to hookup to my component speakers. My problem is this I hook up all the wires and everything and when I connect the wires to the crossovers my midrange speakers work but my tweeters play nothing but static. am i wiring something wrong? with my old amp they worked perfectly fine going thru the tweeter. I am hooking up a hp 2400 orion amp to a set of orions c2 6.2 component speakers and polks DB6501 component speakers. Passive Crossovers
Old 24th February 2009, 11:33 PM   #2
ppia600 is offline ppia600  United States
Default Re: crossover amp hookup
Sounds like the lowpass or bandpass switch is on. Check and make sure the switch on the amp is in full range or high pass/hp mode.
Also, are you sure the orion is a full range amp? It may only play low frequencies/designed for running sub woofers.
Could you post a pic of your amp or give the exact model number?
Don't worry... you can always turn the gain down!
Old 26th February 2009, 11:40 AM   #3
Default hp 2400 orion
yea the amp is hp 2400 its right on there website. The people i bought from says that it is perfect for my component speakers. yea I had switched to full range and then tried high freq still nothing and i know it has to do with amp for simple fact i had my speakers hooked up to a different amp and they worked fine
Hookup wire Buzzy Solid State 6 4th July 2008 01:39 AM
behringer dcx HOOKUP IMSTOOPID Digital Line Level 8 5th February 2008 06:21 PM
Tranny hookup... john65b Power Supplies 11 5th January 2008 08:29 PM
sub hookup questions wharfrat Subwoofers 6 11th July 2004 09:12 PM
Page generated in 0.07722 seconds (70.19% PHP - 29.81% MySQL) with 10 queries
